Go to Post This has to be the hardest, most complicated game I've ever seen the GDC develop - that's what makes it so much fun! - SteveGPage [more]
Unread 14-01-2013, 17:05
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Rookie Year: 2010
Team Pyramid Goal Drawing Incorrect?
According to the Team Field Drawings, the Pyramid Goal is about 26.75'' tall (6'' 2x4, .5'' plywood, 20'' 2x4, and then .25'' plywood). However, according to the Game Manual, the actual one is 30'' tall (https://docs.google.com/file/d/0B8fG...1lcHZ2bTA/edit). Why is there the difference? Thanks in advance.
Also - are the 30'', 60'', and 90'' of the horizontal pyramid bars measured from the bottom of the bar, the middle of the bar, or the top of the bar? The Game Manual doesn't seem to say.
Unread 15-01-2013, 09:30
Hallry's Avatar
Dare to be FIRST
AKA: Ryan Hall
Rookie Year: 2010
Re: Team Pyramid Goal Drawing Incorrect?
Has anyone that has built their pyramid goal noticed this?
Unread 15-01-2013, 09:59
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
The 30", 60" and 90" measurements are to the top of the horizontal members.
As far as the height being wrong, it appears that the field drawings call out for more than a 6" standoff from the top of the pyramid. I think if you make the top of the disc the 120" mark with a 20" (reflective) pole, you should be able to make the standoffs the correct height.
Also note the diference in the amount of chain on the field vs team drawings. I would also suggest using 2"x2" (or slightly smaller) for the pole instead of the 2"x4".
**Disclaimer: I only looked at the drawing for a few minutes.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 15-01-2013, 10:31
juliawillard's Avatar
juliawillard juliawillard is offline
jewels1996
AKA: juliawillard
FRC #2389 (oklahoma storm)
Team Role: Student
Rookie Year: 2013
juliawillard is an unknown quantity at this point
Cool Re: Team Pyramid Goal Drawing Incorrect?
i think that the pyramid goal drawings are still correct on the measure but maybe just not built right
Unread 15-01-2013, 10:34
Hallry's Avatar
Dare to be FIRST
AKA: Ryan Hall
Rookie Year: 2010
Well according to the Team Drawings, the Pyramid Goal is about 26.75'' tall (6'' 2x4, .5'' plywood, 20'' 2x4, and then .25'' plywood), correct? Not 30''.
