Go to Post You wake up at 2:54 am and aren't even mad bc robots - fargus111111111 [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 14-01-2013, 23:03
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Utilizing the Smart Dashboard
Originally Posted by Arhowk View Post
1) How to put a button on the dash? (like putting up a command puts the button to run the command)
I haven't tried it, but it looks like NetworkButton will do what you want.
Unread 16-01-2013, 18:43
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
2) It seems as though the "Save" function only saves the layout of the values and not their value. When you load the robot, SmartDashboard.getNumber() throws a TableNoKeyAtIndex error (meaning that it has no data). Is it possible to make a setup where you open an xml setup and it will automatically send all of the values to the cRIO?
3) What exactly does the "Robot Preferences" widget do? I thought it could be used for #2 but it seems their keys cannot contain [s]strings[/s] spaces //E: the [s] BBCode isnt in this vBulletin?
4) How would i convert a BinaryImage to a Sendable so I can show the BinaryImage on the dash?
5) So.. on the dashboard... I can convert an integer into a progress bar. Is there a way to make it a slider bar so i can input data without converting to plain text?
none answered. shameless bump
Unread 17-01-2013, 12:54
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Rookie Year: 2010
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Anything extending WPILib's Trigger class will show up on the dashboard as a button -- including all of WPILib's Button types.
SmartDashboard's "save" stores what widgets are loaded and their properties (size, color, etc.). SmartDashboard widgets aren't supposed to provide values to the robot; they're supposed to display them and allow them to be tweaked at runtime. If you want a value to stick around, change the value you give to put() on the robot or use Preferences.
The Robot Preferences widget puts a bunch of values into a network table so that the robot can read them. When you hit save, it sends another network table value telling the robot to save. The robot then saves the preference values (assuming you have a Preferences object on the robot) to the file wpilib-preferences.ini on the cRio, to be loaded again at a later time.
I don't even know if this is possible, but I know it would be a really bad idea. While binary images are much smaller than full-color ones, this will still result in a lot of network traffic. You'd have at least two video streams across the network -- one to the cRio from the camera, one to the laptop from the cRio. If you also have a feed to your dashboard, you now have three streams, two of which are full-color, and this becomes quite a load, possibly running over the network traffic limitations. If you want to be able to display different steps of the process live, I recommend doing your image processing on the laptop through a SmartDashboard widget -- for inspiration, you might want to look at Miss Daisy's vision system available here.
I believe you would have to make a custom widget using swing's NumberSlider object. That's what the LiveWindow speed controller widget does.
I code stuff.
