Go to Post In conclusion, we can say, with reasonable certainty, that we know nothing. - Max Lobovsky [more]
Unread 15-01-2013, 02:06
Gadeer Zbedat Gadeer Zbedat is offline
FRC #1946 (Mishka Monster)
Rookie Year: 2012
Gadeer Zbedat is an unknown quantity at this point
How to remove the previous windriver from year 2012?
Hii guys , can you help me \?
Unread 15-01-2013, 12:11
cjlane1138 cjlane1138 is offline
Team 1138
FRC #1138 (Eagle Engineering)
Team Role: Leadership
Rookie Year: 2010
cjlane1138 is an unknown quantity at this point
Re: How to remove the previous windriver from year 2012?
If you have a previous installation, you do not need to reinstall WindRiver. Just make sure to get the updates to the workbench. The WindRiver Workbench is still the same version this year as last year (3.3), so no need to reinstall. Just grab the code update from FirstForge on WPI.
Eagle Engineering 1138
Unread 18-01-2013, 11:21
mprasolov's Avatar
mprasolov mprasolov is offline
Jack of all trades
AKA: Misha Prasolov
FRC #2823 (The Automatons)
Team Role: Student
Rookie Year: 2012
mprasolov is an unknown quantity at this point
Here's what I did:
1) Delete C:\WindRiver
2) Install WindRiver
Just to be safe, and to make sure the problem is not that you didn't reinstall down the road.
Check out our website!
http://hprobotics.org
Unread 18-01-2013, 20:01
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
There are some pretty detailed instructions about half way down on this web page:
http://wpilib.screenstepslive.com/s/...elopment-tools
that describe how to install over an existing WR2012 installation. The problem is that the license from last year is running out and you need to fix that rather than just updating the FRC WPILib 2013 stuff over last years Workbench.
Brad
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
