Go to Post water electricity=bad - Chuck Glick [more]
Unread 15-01-2013, 11:51
Itamar's Avatar
Itamar Itamar is offline
FRC #1943 (NeatTeam) & FRC #4590 (GreenBlitz)
Rookie Year: 2010
Itamar is an unknown quantity at this point
Problems forming NetworkTable between Robot and SmartDashboard
Hello!
We are currently trying to form a connection between the robot and the Smart Dashboard. Here is part of the extension code we have written in Java:
Code:
if (table== null)
            NetworkTable.setTeam(1943);
            NetworkTable.setServerMode();
            try {
                NetworkTable.initialize();
            } catch (IOException ex) {
                Logger.getLogger(TutorialLabel.class.getName()).log(Level.SEVERE, null, ex);
            table = NetworkTable.getTable("RoboRealm");
And here is the robot code we have written in C++:
Code:
NetworkTable::SetTeam(1943);
NetworkTable::SetIPAddress("10.19.43.5");
NetworkTable::Initialize();
roborealmNetTable = NetworkTable::GetTable("RoboRealm");
The Java code runs okay, but the C++ doesn't. When debugging it, we noticed that the code freezes after we call the "NetworkTable::Initialize()" function. What can cause this problem? Can you spot anything wrong with our code?
Thanks!
Unread 15-01-2013, 11:55
cjlane1138 cjlane1138 is offline
Team 1138
FRC #1138 (Eagle Engineering)
Team Role: Leadership
Rookie Year: 2010
cjlane1138 is an unknown quantity at this point
Re: Problems forming NetworkTable between Robot and SmartDashboard
How are you initializing NetworkTable in C++? Is it a static declaration? Could you post the entire class?
Eagle Engineering 1138
Unread 15-01-2013, 11:57
Itamar's Avatar
Rookie Year: 2010
Here is the complete robot code:
Code:
#include "WPILib.h"
class RobotDemo : public SimpleRobot
	Joystick stick;
	Jaguar jaguar;
	NetworkTable* roborealmNetTable;
public:
	RobotDemo(void):
		stick(1),
		jaguar(2),
		roborealmNetTable(NULL)
	void Autonomous(void)
	void OperatorControl(void)
		while (IsOperatorControl())
			if (stick.GetRawButton(1))
				jaguar.Set(stick.GetY());
			else
				double d = roborealmNetTable->GetNumber("InputValue");
				jaguar.Set(d);
			if (stick.GetRawButton(2))
				roborealmNetTable->PutNumber("InputValue", 0);
			Wait(0.005);				// wait for a motor update time
	 * Runs during test mode
	void Test() {
Unread 15-01-2013, 12:08
Team 1138
Rookie Year: 2010
The issue is probably how you are initializing the NetworkTable. You are setting it to null, where it probably should be initialized. I have not yet worked with NetworkTable's, but you can try looking at the WPILib Cookbook. Also, since you have declared a variable, you can use it as a pointer, so instead of this:
Code:
RobotDemo(void):
		stick(1),
		jaguar(2),
You could try this:
Code:
RobotDemo(void):
		stick(1),
		jaguar(2)
                roborealmNetTable = new NetworkTable("RoboRealm");
		roborealmNetTable->SetTeam(1943);
		roborealmNetTable->SetIPAddress("10.19.43.5");
		roborealm->Initialize();
I'm sorry if this is incorrect. This just seems to be the most likely solution to the problem. I will work on NetworkTables later this week. Try this and let me know how it works out!
