Re: *Warning* On talons!!!!
Even with a breaker in place, you can still damage a motor controller with excessive current (e.g. a short circuit). The breakers simply can't react fast enough to save the components in certain situations. That is why "breakers are for preventing fires, not saving the components." Breakers do play a role in component safety, but they need to be used in conjunction with proper electrical design. When using a motor controller...
-David |
Cory,
David points out that short spikes of current will get through.. Check out the circuit breaker spec here. As you can see, a 40A circuit breaker will allow 500% (200A) to pass for 0.2 to 0.3s before tripping. -Scott |
Emphasis on can damage.
I have personally caused a Jaguar failure by connecting a dead short across the motor terminals. This was in early Jaguar testing 3-4 years ago. I haven't personally caused a failure with the others. Scott and I aren't implying that certain exact conditions will or will not damage any of the motor controllers. We're trying stop a common misconception that the breakers instantaneously trip once you go over 40A. They take time, and can't be guaranteed to protect anything but the wiring. -David |
Assuming the datasheet specs for the 40 amp breaker can be trusted, it's possible to design a product around those specs so that the breaker WILL protect it. Hence the question: what are the chances of damaging, say, a Talon, if it is properly wired and protected by a properly operating in-spec 40 amp FRC breaker? I wouldn't lose any sleep over it. Last edited by Ether : 15-01-2013 at 19:47. |
Just some random subjective data, but we've been running fanless Talons in our prototype drivetrain for many weeks now stopping to change batteries and the talons are hardly warmer than ambient to the touch. This is with 4 CIMs and 40a breakers and a ~120lb total robot weight incl. battery (so a bit light) on carpet geared fairly aggressively. I would begin to worry about heating the battery cable and CIMs before I worry about warm talons.
A CIM in a drivetrain will pull full stall current immediately at launch. It will taper down to a much lower level very very quickly, how quickly is dependent on gearing, mass to accelerate, and voltage drop. Use fans if you want. Think of them as speed controller insurance with a 20 gram weight penalty. |
C'est tout. |
I would like to add a little caveat here. While any of the devices can run without fans, please think about your design. You may play fine in a northern regional or in Canada, but come April in St. Louis, the ambient temperature and humidity will change, plan accordingly. While the Talon looks great, time will tell for sure. Please when you give feedback, insure that everyone understands the conditions under which your report is made so that other users and the manufacturer can test and duplicate your results if needed.
Ok,
You will not be able to get 133 amps out of a CIM using an FRC battery, in series with an FRC PD in series with 10 gauge wire and a breaker. The stall current of the CIM is based on a constant 12 volt supply. The power supply on an FRC robot is anything but constant. Factoring in ALL of the components of the robots power supply, the impedance path to the CIM Thevenizes to about 40 milli-ohms. The CIM motor itself has a stall impedance of about 90 milliohms (12/133). Using Ohm's law, the voltage at the CIM will equal about 8 volts for a 100 amp load assuming a 12 volt source, 9 volts assuming a 13 volt source. So your stall current is really 8/.09 = 88 amps or 9/.09 = 100 amps. Another way to look at this is as a simple voltage divider. Vmotor = (Rmotor/Rtotal)*Vbat = .090/(.040 +.090) = 8.3 volts Imotor = Vmotor/Rmotor = 92.2 amps. This is pure DC math and is the absolute maximum that a CIM motor can draw not factoring in the positive temperature coefficient of all that copper inside the CIM or any AC components that add to the path. Another point that I have not seen discussed; Beside the copper in the power path, the circuit breaker has a positive temperature coefficient as well. This causes the breakers impedance to rise exponentially with temperature thus reducing the motor current even further, long before reaching the trip threshold. Bottom line: You will not draw 133 amps with your CIM motor in FRC, not even close. BTW the spec sheet on the Talon reads 60 Amps continuous and 100 peak. The FET's in side the Talon are rated at 100 amps continuous. We de-rate from the 100 amps to be conservative. The reason is because of the heat that is generated at continuous currents higher than 60 amps. |
#10
The peaks don't reach 133A, but they get close in some tests -- duration of the peaks in other test conditions will depend on loading and on motor heating. I have not tried to kill speed controllers by stalling motors (yet). Last edited by Richard Wallace : 16-01-2013 at 12:36. |
#12
For what it's worth, Robot in 3 days used the Talons exclusively. We have an hour or two run time on them and have had no issues. We've fused them as per the motor rules. We did not use fans. Maybe over the weekend we can take some readings on current draw of the different systems. In a purely subjective sense they've handled whatever we've thrown at them.
