Go to Post See, another reason for going--you can find out your chances of being thrown off the field for a safety violation! - EricH [more]
Unread 15-01-2013, 19:59
Team 4264 Team 4264 is offline
FRC #4264
Team 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud of
Bumper question
I have an idea for a bot which would dock with the leg of the monkey bars and "elevator" up while riding on that leg. This would require that the side profile of the bot would match that of the bars @68 degrees, which would make it look like the eastern half of the state of Tennessee. So if I bumper the bottom section of "TN" then the north eastern part of "TN" would hang over the bumpers because of the angle.At least the front portion of the bumpers would have to be made to match this angle. Is this a violation of 4.1.2 -r09, or more?
Unread 15-01-2013, 20:02
Darth Drew's Avatar
Darth Drew Darth Drew is offline
AKA: Andrew
FRC #1701 (Robo Cubs)
Team Role: Student
Rookie Year: 2011
Darth Drew is an unknown quantity at this point
Re: Bumper question
If you have that side of you robot over 16" long the excess doesn't have to be bumpered (you have to have 8" of bumper on each corner).
Join me and together we will rule the galaxy
Unread 15-01-2013, 20:45
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Bumper question
4.1.1.4 R04
In the STARTING CONFIGURATION, no part of the ROBOT may extend outside the vertical projection of the FRAME PERIMETER, with the exception of minor protrusions such as bolt heads, fastener ends, rivets, etc.
Al
WB9UVJ
www.wildstang.org
________________________
