Go to Post "Who needs finesse when you have air pressure?!" - neelpatel1710 [more]
Unread 15-01-2013, 20:53
JTW JTW is offline
FRC #4143
JTW is an unknown quantity at this point
Question Dashboard data type?
Where is the dashboard data type (from the Dashboard main Vi) in the 2013 Labview? Previously it was a large cluster outlined in pink on the left.
Unread 16-01-2013, 01:48
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
Re: Dashboard data type?
That was replaced with SmartDashboard. Look for a new palette on the lower-right of the WPILib Robotics palette.
Unread 16-01-2013, 07:13
The low and high priority data is still available if you want to use it, but it isn't promoted because SmartDashboard is pretty powerful, works across languages, and is easier to use.
If you want to continue using the unflattened data buffers, you can put the data casting back. There is really no need to send all of the I/O data that was done in past years, just send what you are interested in.
Greg McKaskle
Unread 16-01-2013, 17:32
propionate's Avatar
propionate propionate is offline
Team co-lead and LabVIEW programmer
AKA: Stephen
FRC #1732 (Hilltopper Robotics)
propionate is on a distinguished road
Greg McKaskle
Piggy-backing on this thread, does anyone have a good link to the instructions for using the SmartDashboard? This will probably be helpful for the original poster as well.
Unread 16-01-2013, 18:24
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
https://decibel.ni.com/content/docs/DOC-26296
Unread 21-01-2013, 16:43
JTW JTW is offline
FRC #4143
Smile Re: Dashboard data type?
Thank you for your help. I am sure this will help our team!
