Go to Post From what I've seen in FIRST, teams that copy generally always learn something from it, and if they don't, the copy they produce is of much lower quality than the original. - TheOtherGuy [more]
Unread 15-01-2013, 21:32
Reggie335 Reggie335 is offline
AKA: Reginald
FRC #4297 (WeNoRobots)
Team Role: Leadership
Rookie Year: 2011
Reggie335 is an unknown quantity at this point
Bumpers Issue
Those any know how to put bumpers on a 31" Nano Tube drive Base
Unread 15-01-2013, 22:33
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
Re: How to Put Bumpers On Toughbox Nano Tube
I posted this about what we're using on our Nano Tubes. We have the 20" models though, to fit in this year's size requirements you're going to need to reduce the C-base chassis mounts to be closer to the frame in addition to making the robot VERY narrow.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
Unread 15-01-2013, 22:44
lorem3k's Avatar
lorem3k lorem3k is offline
1 + 1 = 0 (in Z/2Z)
AKA: Andy D.
FRC #1482 (Bishop Grandin Ghosts)
Rookie Year: 2011
lorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to behold
Instead of using the C-channel connectors, you can also run outboard wheels and build your bumpers above. This is what we plan to do with ours. I think this will only fit the rules regarding the bumper zone if you use 4-inch or smaller wheels, though.
Boo! Bishop Grandin High School / GM Canada / Tenaris
2013 Western Canada - Quarterfinalists (thanks 288/4719) / 2012 GTR West - Quarterfinalists (thanks 188/1075) / 2011 GTR East - Regional Winners (thanks 1114/1503)
Unread 16-01-2013, 12:56
HumblePie's Avatar
HumblePie HumblePie is offline
AKA: Mista Doug
FRC #3489 (Category 5)
Rookie Year: 2010
HumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really nice
We like using the 1" square tubing available from 80/20, as the rounded corners make them a sweet fit with the kit channel. The kit channel can be cut into sections, mounted to the bumper backing, then drill mounting holes through the square tube at final assembly. A ball lock pin can hold everything securely in place. Pictured is a way we did it last year. We've had to modify it a bit this year due to size constraints, but you'll get the idea. If you'd like more detail on this year's version, PM me.
Name:	6WD Nanotube with Bumper Supports.JPG
FRC Team 3489 "Category 5"
