Go to Post The moral of this story is that constructive criticism is good, but only as long as you don't act like a complete idiot. - David Kelly [more]
Unread 15-01-2013, 22:07
TheChosen1 TheChosen1 is offline
Software Wizard
FRC #2840
Rookie Year: 2012
TheChosen1 is an unknown quantity at this point
Smart Dashboard camera widget does not appear
Ok, so after going through this tutorial, in an effort to get the camera working on SmartDashboard, I ran the installed version of SmartDashboard (both through the Driver Station, and through the actual file itself) and I found that no widget would actually appear when I clicked on View>Add>camera, effectively making it so that I would see neither a camera feed, nor a black box that lacked a camera feed. The thing that puzzled me so much, though, is the fact that when I run View>Add>Laptop camera I see a light next to my webcam indicate that the webcam is in use, but still no image or widget appears on SmartDashboard, seeming to imply that there is something installed to SmartDashboard, but I, for some reason, can not see it.
Unread 17-01-2013, 18:46
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
Rookie Year: 2010
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: Smart Dashboard camera widget does not appear
Make sure Windows Firewall and your Antivirus is off. Check if anonymous viewing is on. Check if your camera stream fps is 30, for some reason SmartDashboard camera widget will not work if the FPS is too low.
Unread 28-01-2013, 22:53
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Thanks for the above advice about setting the stream fps to 30. I don't know why, but if we set the fps to 20, the image does not show up in the SmartDashboard!
We had our cameras set to 20fps for our vision processing last year, so it worked at 20fps last year, but the new SmartDashboard does not seem to work at 20fps.
I am able to change only the fps setting to 30fps, and the SmartDashboard starts working -- set it back to 20fps, and it no longer works -- set it back to 30fps, and it works again!
Brad Miller, any ideas as to why this might be? Can you reproduce this behavior in your test setup?
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
