Re: Prototype Small Wheeled Shooter
If the frisbee is not exiting that second wheel at 60 mph it might be because it is slipping. So, either: 1) crank down the speed of that second wheel a bit to stop the slipping and get a higher exit speed, or 2) crank up the speed of the first wheel, which is presently only 1930 rpm, which translates to 16 mph tangential velocity or 8 mph exit speed. A higher exit speed from the first wheel means a higher entry speed into the second wheel, which may reduce the slipping in the second wheel and give a higher exit speed * I realize that due to windage and vibration it will be less than that |
Not easily using the VersaPlanetary they have, only 3:1, 4:1, 5:1 and 10:1 single ratios.
Ether, what exactly are you trying to get us to test? We were able to pull back about 80-75% on the joystick before we noticed any distance change. We still know the front wheel is slipping. We're pretty happy with the setup as it is, since we can meet all of our design goals and more. We won't be doing too many more changes to the shooter configuration. Once we get some other systems improved, we will be adding light sensors and white lines to the wheels so we can do bang-bang speed control and more precisely control our distance.
Also, anyone have any ideas as to how you mount the banebots wheels directly to a CIM? Thanks |
On their blog they explained that they used a Versaplanetary box with all of the gears within removed. The output shaft of the VP boxes are the same hex as the banebots wheels.
Thanks, didn't see that there.
Also we were wondering how you direct drive the banebots wheels with a CIM. |
Locking a stage in a planetary gear is fairly simple - look up how people did it with globe motors. It involves glueing the sun gear and planetaries together with something, then dremeling off the teeth of the planetaries so they don't touch the ring gear. FYI, you can't really be guaranteed that you can direct drive a banebots with a cim without installing an insert and broaching it with a keyway. The unfinished bores on the banebots wheels are not actually a measured diameter: it varies. They ream it to .375, but in most cases it comes bigger than the 8mm shaft of a cim from their manufacturer, and hence will not work directly on a cim. Last edited by Tom Line : 16-01-2013 at 12:27. |
#10
The three 0.4" wheels fit perfectly. The two .8" wheels have about .5" sticking over the top of the shaft, we just put a longer 1/4-20 bolt on with a washer, seems to work well enough.
#14
Why did you go with 2 different wheel thickness? Just what you had around?
#15
The .4" orange wheels can be bought using the BB PDV. We purchased 2 .8" of all three colors after we tested how grippy they were to the discs. We just left the .4" ones on there for now. We'll best testing a bunch of different wheel combinations over the next week.
