Go to Post Wow. Just wow. Never did I think the mentor built robot debate would make it on to a tv show. - ASD20 [more]
Unread 16-01-2013, 15:06
Akshay Akshay is offline
FRC #1100
Rookie Year: 2010
Akshay is an unknown quantity at this point
Field Calc / Measurement Tool
Hello,
I have created a tool to aid in field calculations,so that it may be easier to figure out a strategy or design Frisbee shooter positions. I was hoping to get some feedback and release it for general use at the same time. Instructions are on the page.
Field Calc Tool
If I have posted in the wrong place, please let me know.
Unread 16-01-2013, 15:11
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
Re: Field Calc / Measurement Tool
I like this, we have been doing this math in Solidworks but it's much easier with a simple applet. Thanks for posting this.
Where on the goals is it taking it's measurement from? The center face of the goal or somewhere else?
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 16-01-2013, 15:13
FRC #1100
Rookie Year: 2010
It is taking measurements from the point you define to the centers of the goals.
Unread 16-01-2013, 15:15
Engineering Coach
Team Role: Coach
Originally Posted by Akshay View Post
It is taking measurements from the point to define to the center of the goal.
Center of the goals, as in depth as well?
Unread 16-01-2013, 15:17
FRC #1100
Rookie Year: 2010
Its a little bit inside...not an exact amount. I put them about 6-12 inches in.
Unread 16-01-2013, 15:19
Engineering Coach
Team Role: Coach
I think the numbers would be more useful if it was at the face of the goal. That is what most people are aiming for, I think.
Unread 16-01-2013, 15:26
FRC #1100
Rookie Year: 2010
Thanks, I have updated the program to use the outside face of the goals. It is still centered.
Unread 16-01-2013, 15:29
Engineering Coach
Team Role: Coach
So if I'm standing at the 27 foot center line on the field in front of a goal, it should say I have to shoot 27 feet? That's what I would assume most people would want because that makes sense as to where that dot is. Maybe I'm off here but that's how we have been doing things.
Unread 16-01-2013, 15:40
FRC #1100
Rookie Year: 2010
Height is also accounted for. The ground distance gives you the 27 feet, but the direct distance uses the height of the goal, so that distance is a little more.
Unread 16-01-2013, 15:46
Engineering Coach
Team Role: Coach
Okay, it's working now. Thanks for putting this together we will be using fairly regularly.
Unread 16-01-2013, 15:49
FRC #1100
Rookie Year: 2010
Was something not working correctly? The only thing I changed was the goal positions.
Also, good to know it will be used.
