Go to Post Reffing a FIRST event is unlike being an ump or a ref at any other event. Where else is a game invented each year and over 1000 teams play this game within 3 months of its birth? - Andy Baker [more]
Unread 16-01-2013, 16:06
xtantheta xtantheta is offline
FRC #1554
xtantheta is an unknown quantity at this point
Vability of a particular climbing system
One of the members of my team suggested a pneumatic-run method of climbing: the bot goes in the inside of the 'mid, and slowly elevates itself using as many pistons as is feasible to push off the ground. A pole touches level 1, and a hook is positioned *above* level 2. The air is released faster than the acceleration due to gravity so the pistons retract, and the robot falls, but this hooking mechanism lands on level 2. Yes, it goes airborne for a split. It is dubbed "flying with style".
Now I know that we probably shouldn't use a coat hanger and duct tape for the hook, so I was wondering what was okay. Is a standard steal hook fine? Should we use more than one or two?
Many thanks for any and all help that you can give us. The more precise (and perhaps mathematical) the responses, the better.
Good luck to all the other teams in their goal of climbing!
Unread 16-01-2013, 16:16
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Re: Vability of a particular climbing system
I had a similar idea, but mine was to have a hook go up to level 3, touch level 1, have a second arm below level 2, Have the robot jump and catch level 3.
A steel, aluminum, wood hook should all be fine, it all depends on how you build it.
Do you or someone else have any math to back up that the pistons retract faster than the robot falls?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 16-01-2013, 16:32
FRC #1554
I was thinking that simply having many small pistons evenly distributed across the base of the robot would sufficiently hold it up, and the fact that they're small (with a lot of them for a large amount of PSI) would mean that they retract very quickly. I assume that it would not be especially difficult to have them operate in tandem.
Unread 16-01-2013, 18:04
Darth Drew's Avatar
Darth Drew Darth Drew is offline
AKA: Andrew
FRC #1701 (Robo Cubs)
Team Role: Student
Rookie Year: 2011
Darth Drew is an unknown quantity at this point
I think the fact that you want to go airborn will significantly increase the durability of the hooks you need, but I don't have data to back it up
Join me and together we will rule the galaxy
Unread 16-01-2013, 18:28
pichu2415 pichu2415 is offline
FRC #3176
pichu2415 is an unknown quantity at this point
You do know you can't touch more than two levels at a time, or jump levels... right?
Unread 16-01-2013, 19:03
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Yes I know, touch level one from the top, hold another arm below level 2. and have your grasping mechanism under level 3. have your Robot jump, when it does it will stop touching level 1, touch level 2, then grab onto level 3. then pull yourself up.
Kevin Li
596 - Sciclones
Unread 16-01-2013, 19:32
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Do you have any idea how much moment force that would put on a hook?
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 16-01-2013, 20:33
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
I see what your saying and think that a drawing might help others understand your plan.
Unread 16-01-2013, 21:21
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Retracting the jacking cylinders simultaneously will be complicated by the lengths of tubing and locations of the solenoid valves involved. The longer the path for the escaping air the slower it will travel, much like current in a higher resistive circuit. That said, you may even want one side of the robot to start falling earlier if you're depending on a slight tilt to engage your second rail hook. It's similar to building demolition that sets off the severing charges in a calculated sequence to get the building to fall in a certain direction.
You should be able to devise an small experiment to see if the retraction happens fast enough. Suspend a small ball with an electromagnet. position it the same distance above the table that you want the hook to fall. Devise a single push button switch that releases the air in the cylinder via a solenoid valve AND interrupts power to the electromagnet. It's now a race to see if the ball hits the deck before the cylinder is totally retracted. Repeat observations until you're convinced one way or the other about how fast that cylinder can retract.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
