Go to Post FIRST needs a disclaimer that parts of the field can become flying projectiles under hurricane force winds. - Barry Bonzack [more]
Unread 16-01-2013, 16:41
SPFDEXP SPFDEXP is offline
FRC #2549 (Millerbots)
Team Role: Driver
Rookie Year: 2010
SPFDEXP is an unknown quantity at this point
Drive Belt vs. Chains
So our team is discussing using a drive belt instead of chains for our chasis. I want to know peoples opinion regarding using belts? Has anyone used a drive belt on thier robot? And how did it work out for you? Would you reccomend a drive belt? Id love to see some drawings or pictures of robots with drive belts whether its a new or old robot.
Good Luck
Team 2549
Unread 16-01-2013, 16:59
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Rookie Year: 2011
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Drive Belt vs. Chains
The kit frame is belt driven this year.
And we are doing a belt drive WCD, using Gt2 9mm belts and custom machind pulleys.
I know 973 did a pretty slick off season belt drive and I believe 11 MORT has been doing it for awhile to. They work great if you can design it properly.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 16-01-2013, 17:04
Team Role: Driver
Rookie Year: 2010
Ok thanks. Do you have any experience with them? Do you know how reliable they are and if they're better than the chains from previous years? We have never used belts and we need as much information regarding belts.
Good Luck
Team 2549
Unread 16-01-2013, 17:15
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
Team Role: Mechanical
Rookie Year: 2011
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
If you don't know much about belts, it would probably be better to use chain, since they can be daunting. We haven't had many problems with either, though. The important part is that in either case, you make sure to include some way to adjust tension.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 16-01-2013, 17:20
Team Role: Driver
Rookie Year: 2010
The reason we're looking at belts is to cut down on weight for climbing. Do you have any pictures of your drivetrain with belts?
Good Luck
Team 2549
Unread 16-01-2013, 17:34
EricDrost's Avatar
EricDrost EricDrost is offline
Eleven to MidKnight
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
We've had a lot of success with using belts in the drive system. It does not provide any more efficiency than chain, but it just makes the drive a bit cleaner. If you space them correctly, they'll never break and rarely slip. We've gone through 5 event seasons with no upkeep necessary.
If you have any questions, feel free to PM me!
MORT Team 11: 2008 - 2015
MKI Team 1923: 2015 - Present
Unread 16-01-2013, 18:29
Darth Drew's Avatar
Darth Drew Darth Drew is offline
AKA: Andrew
FRC #1701 (Robo Cubs)
Team Role: Student
Rookie Year: 2011
Darth Drew is an unknown quantity at this point
My team had a bad experience with chains 3 years ago. Our frame was to flexible and the chains would frequently come off of one or both sides of the drive train so either way, make sure your frame is durable and stiff enough to prevent this from happening.
Join me and together we will rule the galaxy
Unread 16-01-2013, 22:19
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
Rookie Year: 2012
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Not quite true, but the efficiency difference isn't so great as to be considered over other factors such as weight or complexity.
http://www.chiefdelphi.com/media/papers/2246
•Belt drive is 3% to 4% more efficient than chain.
•Belt was 6% faster to set distance from stop
•Belt traveled 8% farther for given power input
•Belt was 14% faster in speed test after initial acceleration
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 16-01-2013, 22:35
Chris is me's Avatar
AKA: Pinecone
It's week 2 of build season. If you don't have experience with belts yet, don't do it.
All the advantages in the world aren't worth a drivetrain with mechanical problems.
If you are so close on weight that you are changing from chain to belt to make room for hanging... There's got to be weight you can remove elsewhere.
Unread 16-01-2013, 22:55
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
You can't do belt with a WCD if you are doing an internal cross member. With an internal cross member it is impossible to get the build in/out without dis-assembly of the frame. That said, that's an easy thing to get around(cross member over the rails/no cross member).
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 17-01-2013, 00:40
Mugurussa675 Mugurussa675 is offline
FRC #0675
Team Role: Driver
Rookie Year: 2011
Mugurussa675 is on a distinguished road
If you don't have any experience with belts then use chain. However if you have experience with belts or know someone who has experience using belts, use belting. I only say use belting because its significantly lighter then chain, and to some aspects easier to use. Such as you don't have to deal with breaking the chain and re-attaching together.
Unread 17-01-2013, 11:37
karomata's Avatar
karomata karomata is offline
Rebellious Egyptian
AKA: Mo Elhelw
karomata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud of
My team has had many bad experiences with belts, so we tend to stick with chain. In 2011, we had belts drive our tube manipulator, and the belts would slip and it would render it ineffective. Chains rarely slip, normally they just snap or break, but its much harder to get a chain to malfunction than it is to get a belt to malfunction.
Unread 17-01-2013, 17:17
pmangels17's Avatar
AKA: Paul Mangels
Rookie Year: 2011
http://www.youtube.com/watch?v=MgYnw...XrOpK1&index=2
This is a great resource to see an effective way of running power transmission in a WCD, or any other base style, for that matter.
Unread 17-01-2013, 18:44
AKA: Pinecone
If you haven't figured out a drive design by now I would definitely not do something so complicated. The design is quite complex and can easily be hard to maintain.
  #15   Spotlight this post!
Unread 17-01-2013, 23:00
pmangels17's Avatar
AKA: Paul Mangels
Rookie Year: 2011
That is also true, and I should have mentioned it. A simple, robust drivetrain goes a long way in FRC, and more complex designs need time to be developed.
