Go to Post Courtesy is the key. - Tom Schindler [more]
Unread 16-01-2013, 16:43
Ideal_Nerd's Avatar
Ideal_Nerd Ideal_Nerd is offline
Team Caption
FRC #3591 (Wild Warbots)
Team Role: Driver
Ideal_Nerd has a spectacular aura aboutIdeal_Nerd has a spectacular aura about
disk hopper ideas
our team has a shooter made and is now wondering what the best way to store and load the disks in to the shooter. our biggest concern is that the disks wont go in and lay flat. we are also trying not to use pneumatics in our robot.
Unread 16-01-2013, 17:40
Darth Drew's Avatar
Darth Drew Darth Drew is offline
AKA: Andrew
FRC #1701 (Robo Cubs)
Team Role: Student
Rookie Year: 2011
Darth Drew is an unknown quantity at this point
Re: disk hopper ideas
Our team had similar concerns about using a magazine style feeder, that the frisbees would overlap and not enter the shooting chamber cleanly, so we decided to use a sliding feed mechanism, similar to what Robot in Three Days used. We haven't prototyped it yet but it seems like it should work.
Join me and together we will rule the galaxy
Unread 16-01-2013, 18:27
Aroki's Avatar
Aroki Aroki is offline
FRC #1787 (Flying Circuits)
Team Role: CAD
Rookie Year: 2012
Aroki will become famous soon enoughAroki will become famous soon enough
We're planning on using part of a 5 gallon bucket as our magazine feeder, it works as a funnel to help orient the frisbees so they should be stacked cleanly at the bottom of the magazine
Unread 16-01-2013, 20:17
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
We too, were prototyping with the top of a 5 gallon bucket, it is the perfect size and its light. probably will end up on the robot.
Unread 18-01-2013, 22:30
Slartibartfest Slartibartfest is offline
FRC #1758
Slartibartfest is an unknown quantity at this point
You know it's the little things like "The disks fit perfectly inside a 5 gallon bucket." that make life so much easier. Although my team is opposed to it I want a 5 gallon bucket feeder; THE DISKS DO NOT OVERLAP. At least not enough to worry about, they way they curve the edges go out and back in preventing one from falling all the way on top of the other so you con stack them one on top of the other and push the one on the bottom out without affecting the others too much. Here is a good example http://www.youtube.com/watch?NR=1&v=JziVZvfsA3c.
Unread 18-01-2013, 22:47
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We got our prototype working. But it is designed to use pneumatics...because we want to use them for another robot feature, and they're easy once you get the compressor running and the plumbing for the pressure regulator figured out.
http://www.youtube.com/watch?v=WddNQfBA5Cw
Unread 18-01-2013, 23:02
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
What advantages do a five-gallon bucket give that three aluminum posts don't give at less weight?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 19-01-2013, 03:06
ttldomination's Avatar
ttldomination ttldomination is offline
Sunny
Rookie Year: 2007
ttldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond repute
My immediately response to that would be error correction. With the three posts, I suppose there's a way for a frisbee to deform out.
HOWEVER, I do not necessarily believe that the advantage will be terrible great. With a properly tuned system, I expect the differences to be greatly marginalized.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 19-01-2013, 07:14
ohrly?'s Avatar
ohrly? ohrly? is offline
Griffin Alum
AKA: Colin Poler
FRC #1884 (The Griffins)
Rookie Year: 2011
ohrly? is an unknown quantity at this point
We probably won't be using this on our robot (doesn't work so well with our feeder design).
It keeps the frisbees separated so that they do not stick together.
http://youtu.be/YhE55Yjt03M
Unread 19-01-2013, 07:31
ohrly?'s Avatar
Griffin Alum
AKA: Colin Poler
Rookie Year: 2011
This doesn't integrate with our feeder design, so I thought I would share.
The spurs keep the frisbees separated so that they can slide out easily. The spurs are acrylic, riding on lego axles.
http://youtu.be/YhE55Yjt03M [I don't think I have the rep to link]
Unread 19-01-2013, 10:13
Xeneria Xeneria is offline
AKA: Sean Kim
FRC #2537 (RAID)
Rookie Year: 2010
Xeneria is an unknown quantity at this point
Would you be willing to supply the CAD file for the spurs? They are a great idea to limit the sophistication of the hoopers.
Raid 2537
Unread 19-01-2013, 10:54
ohrly?'s Avatar
Griffin Alum
AKA: Colin Poler
Rookie Year: 2011
Ok! IPT, DWG and DXF attached.
Unread 19-01-2013, 10:57
MrForbes's Avatar
AKA: Jim
The spurs are a neat idea!
