Go to Post From what I've been told, it's BASIC. Just BASIC. Basic BASIC. Basically BASIC. To be basic, it's BASIC. - Aignam [more]
Unread 16-01-2013, 21:06
eklaw eklaw is offline
eklaw is an unknown quantity at this point
compression: wheel vs wall
Has your team experimented with having a compressible wheel vs wall? What did you find? In theory it shouldn't effect contact length.
Unread 16-01-2013, 21:51
mklinker's Avatar
mklinker mklinker is offline
Coach FRC4485
AKA: Mike Klinker
FRC #4485 (Tribe Tech Robotics)
Rookie Year: 2013
mklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to behold
Re: compression: wheel vs wall
Our prototype allows for adjustment of both. We have had the most success with allowing for maximum wheel compression. We have the 8" AndyMark Pneumatic wheels with less air than maximum and can now throw a frisbee 50 feet consistently.
We will be experimenting with the tire pressure variable tommorrow.
Unread 17-01-2013, 00:54
Mugurussa675 Mugurussa675 is offline
FRC #0675
Team Role: Driver
Rookie Year: 2011
Mugurussa675 is on a distinguished road
My team set up a shooter on 80/20 rails so we could adjust compression, then we used H beams from Mcmaster as thr walls. On one side we had 2 cims that had the 6 inch super grip wheels from andymark. On the other side was another H beam that had a strip of Poly Urethane Belting from mcmaster. We have it so the wheels make enough contact on the Frisbee so once it touches the wheels it remains on at least one till it exits. Then its compressed up to the wall with urethane belting. We were able to shoot about 60 feet. Its a little much but we'd rather shoot further then shorter If you have any questions or wanna see a picture just shoot me a message.
FRC Team 675
Drive team
Team Leader
Manufacturing Leader
Unread 17-01-2013, 07:31
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
Rookie Year: 2012
DavisDad will become famous soon enoughDavisDad will become famous soon enough
I was speaking with a mentor from another team. they had done extensive testing with wheel types. They found that a soft pneumatic tire, partially deflated, achieved the best "grab" on the Frisbee. He described the performance as" when the disk goes through the pinch-point, the tire wraps around the edge; compresses to conform to the Frisbee shape.
