Go to Post I wish I had the blissful self-confidence of some of our students, even if it is a little delusional. It's all part of the process. - John Neun [more]
Unread 16-01-2013, 23:48
WarehouseCrew WarehouseCrew is offline
FRC #3299 (Warehouse Crew)
Team Role: Parent
Rookie Year: 2010
WarehouseCrew is an unknown quantity at this point
Small wheel options
Can anyone recommend some smaller wheels to try for the shooting mechanism? I understand team 3847 used Banebot wheels successfully, but I would like to hear if others have used other wheels that have also worked (and where you can buy them from).
If using a non-Banebot wheel, how are you mounting the wheel to your shaft (either gearbox or direct drive on CIM, etc.)? Most of the wheels I've seen are designed with bearings to spin freely on a shaft.
Thanks.
Unread 17-01-2013, 00:02
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Rookie Year: 2010
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Re: Small wheel options
http://www.vexrobotics.com/vexpro/wh.../217-2903.html
This is what I'm thinking of using on ours. It would be driven directly off of a CIM using an AM style hub after we mill the nubs off of the built in hub of the wheel.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 17-01-2013, 00:10
Team Role: Parent
Rookie Year: 2010
Does the wheel's tread pattern (eg. not smooth) work well for shooting discs?
Unread 17-01-2013, 00:19
Build Lead
Rookie Year: 2010
I should have been more clear in my original post. We haven't actually tried them yet. Though their size and price ($4.99) make them really attractive.
I don't foresee any problems with the tread pattern (one of our prototypes used a wedgetop pattern). If there are any we can just expedite the wear process by introducing the tread to our sander. The trick would be to take off enough to make the surface even, but leave enough to still get some grip on the disk.
Unread 17-01-2013, 00:20
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
These are the wheels we used before the Banebots and they worked very well but were still a bit big for us. We were looking for them in 1/10th scale but non of the pre-mounts seemed to be foam filled like the 1/8th scale ones. We just drilled the 1.625 hole pattern into it and mounted it to an Andymark Hub.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 17-01-2013, 00:22
TheMadCADer TheMadCADer is offline
Rookie Year: 2010
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
I haven't seen them tested, so you'd really have to just try it to find out. I would guess that it would not be very good, since the tread pattern decreases the area of the wheel that is contacting the disc as it goes through the shooter.
However, I think the problem with them will be more related to how firm the tread is. If you've ever held one of those VEX Pro versa wheels you'll know that they're very hard to the point that the tread's edges are sharp to the touch. Something that almost all teams have found is that wheels that can compress are better, since they get better contact with the disc.
Unread 17-01-2013, 09:10
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
Team Role: Coach
Rookie Year: 2010
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
We're using the Andy Mark larger pneumatic wheels and straight CIMS. We've got standard sized wheels (6"-standard kit bot wheels from next year). Hopefully our build team has the dimensions correct and the wheels won't be pushing the envelope...ha...the cylinder.
Unread 17-01-2013, 09:16
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
We're in the process of trying some colson wheels as an improvement on our design. They're light-weight, come in lots of sizes, and are easy as pie to hex broach.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 17-01-2013, 10:57
Team Role: Parent
Rookie Year: 2010
How do you hex broach these wheels? We have very basic tools (eg. our school doesn't have an industrial arts program or shop).
Are these the wheels you are referring to? They don't look like they compress (eg. hard rubber).
http://www.robotmarketplace.com/prod...on_wheels.html
Unread 17-01-2013, 11:29
AlexH AlexH is offline
Rookie Year: 2010
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
colson wheels are 65a, banebots wheels range from 55a to 30a. the green banebots wheels (30a) are super squishy and wear out really fast. colsons will last forever.
coslon wheels are essentially shopping cart wheels
mcmaster also has a pretty good selection of small dia rubber wheels
http://www.mcmaster.com/#caster-wheels/=l2qt4x
My Instructables
Unread 17-01-2013, 11:39
pfreivald's Avatar
Those are indeed the wheels, and you are correct that they don't compress much. This can be but doesn't have to be a problem when it comes to shooter design.
Broaching requires (a) a press of some kind (arbor press or bottle jack press), and (b) a broach. The process is (1) drill hole to correct diameter for broach (if not already that size), (2) insert broach, (3) press through hole -- but make sure things are square, because any side load on the broach will probably shatter the hard steel.
A press necessary for plastic or aluminum wheels/sprockets/etc is less than a hundred bucks. A half-inch hex broach is about $215, but unless you break it you only need one.
A keyway broach is cheaper -- you can get a set of them suitable for FRC-sized applications for around $200 -- but having switched to hex broaches this year I don't think I ever want to go back!
On a side note, over the course of several years we bought a small mill, lathe, arbor press, and bench vise and mounted them on a four-wheeled, heavy-duty cart, and put a bunch of drawers underneath to store hardware (nuts, bolts, rivets, washers, etc, etc). This "machine cart" cost us around $1500 total for everything, and sees near-constant year-round use. It fits through doors, doesn't take up too much space in an FRC pit (or our storage closet), helps with organization, and two people can push it up/down whatever ramps we need to get it up/down.
I would recommend that any team that doesn't have access to a machine shop set about acquiring these things as budget permits. It took us longer than we wanted it to, but it's very, very worth the investment. You go from, "holy cow, how are we going to attach that motor to that wheel?" to "hey, you whip up a couple of motor couplings while I mill out the plate."
Team 1551
I write books, too!
Unread 17-01-2013, 12:43
commodoredl commodoredl is online now
AKA: Dan Lavoie
FRC #2877 (LigerBots)
Rookie Year: 2007
commodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud of
Patrick, would you mind sharing more information about your "machine cart?" Pictures, product information, etc.
Being part of a team that has never done much machining with the students, I'd love to find an economical solution to get them started in that area.
Technical Mentor
Team 2877 - Ligerbots
2016-
Previously:
Team 578 - Red Raider Robotics
2007-2014
Unread 17-01-2013, 15:10
pfreivald's Avatar
If you want to come down and check it out any time, you're certainly welcome -- Naples isn't that far from Fairport. (I first heard about FRC while student teaching at Fairport, if you didn't know...)
We'll have it at FLR, too -- it's the same one we had last year.
The lathe, mill, and some tools came from Micro-mark.
http://www.micromark.com/microlux-7x...athe,9615.html
http://www.micromark.com/microlux-hi...hine,9616.html
Looks like prices went up a bit since we got ours, but not a whole lot. In addition to the machines themselves, a good collet set, center finders, parallel bars, cutters, etc can run several hundred to thousands and thousands of dollars depending on what you choose to get. I can't elaborate on those exactly because they were sourced and donated by others -- a machinist willing to donate some time could suggest what a good starting set of stuff would be.
The arbor press was picked up at a garage sale. New ones run under $100 for the same tonnage.
For lathe practice, delrin works great because it's easy on your tools, and if you go this route please don't buy any. I think I have 20934870974326204987 lifetime supplies of 1.5" delrin rod in 12' sections that were donated to us last year.
Team 1551
I write books, too!
