Go to Post Programmer's pride. FIRST needs some more. - Ben Margolis [more]
Unread 01-17-2013, 06:51 AM
salandri_s's Avatar
salandri_s salandri_s is offline
FRC #4145
salandri_s is an unknown quantity at this point
Scheduler.getInstance().run() throws a null pointer
Scheduler.getInstance().run() throws a null pointer exception. Anybody encountered same problem and found a fix? If yes, please share.
Unread 01-17-2013, 07:18 AM
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: Scheduler.getInstance().run() throws a null pointer
It's unclear if the Scheduler call is throwing a null pointer, or if one of your commands is. Can you post the full stack trace?
Unread 01-17-2013, 11:10 AM
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
Rookie Year: 2012
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
It's sure to be an exception being thrown in .run() since it is a singleton instance. Something in your scheduled commands is throwing the error.
All opinions are my own.
Unread 01-17-2013, 12:52 PM
salandri_s's Avatar
FRC #4145
Thanks for responding.
Here is the exception stack trace.
[frcrun] [cRIO] 1969/12/31_16:04:53.119,E,WkwFrcRobot2013,teleopPeriodic() ,java.lang.NullPointerException, message=Cannot put a null value into networktables.
[frcrun] [cRIO] java.lang.NullPointerException: Cannot put a null value into networktables
[frcrun] [cRIO] at edu.wpi.first.wpilibj.networktables2.NetworkTableN ode.putValue(NetworkTableNode.java:95)
[frcrun] [cRIO] at edu.wpi.first.wpilibj.networktables.NetworkTable.p utValue(NetworkTable.java:406)
[frcrun] [cRIO] at edu.wpi.first.wpilibj.command.Scheduler.run(Schedu ler.java:208)
[frcrun] [cRIO] at us.oh.k12.wkw.robot.WkwFrcRobot2013.teleopPeriodic (WkwFrcRobot2013.java:331)
[frcrun] [cRIO] at edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.otBase.startApp(RobotBase.java: 169)
[frcrun] [cRIO] in virtual method #10 of javax.microedition.midlet.MIDlet(bci=17)
[frcrun] [cRIO] at javax.microedition.midlet.MIDletTunnelImpl.callSta rtApp(64)
[frcrun] [cRIO] at com.sun.squawk.imp.MIDletMainWrapper.main(110)
[frcrun] [cRIO] in virtual method #95 of com.sun.squawk.Klass(bci=25)
[frcrun] [cRIO] at com.sun.squawk.Isolate.run(1506)
[frcrun] [cRIO] at java.lang.Thread.run(231)
[frcrun] [cRIO] in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[frcrun] [cRIO] ijava:165)
[frcrun] [cRIO] at edu.wpi.first.wpilibj.RobotBase.startApp(RobotBase .java:169)
[frcrun] [cRIO] at cn static method #3 of com.sun.squawk.VM(bci=6)
Unread 01-17-2013, 12:58 PM
AKA: Joel Gallant
Rookie Year: 2012
It appears that it has nothing to do with Scheduler.run(). Are you using NetworkTables to send and receive data in any way (or SmartDashboard)? It seems you've sent a null reference through NetworkTables.
Unread 01-17-2013, 05:10 PM
detruby detruby is offline
Dave Truby
AKA: Dave Truby
FRC #4145 (Wolf Pack)
Rookie Year: 2012
detruby is an unknown quantity at this point
In wpilibjava jar, in Scheduler.java line 208,
m_table.putValue(string.valueOf(++count), e.getData().getTable());
Would return the error about putting a null in the network table. Looks like a code bug to me.
Unread 01-20-2013, 03:31 PM
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
Can you post a (preferably) small program that causes the NULL pointer exception that you are seeing?
Thanks,
Brad
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 01-21-2013, 01:38 PM
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
We had this issue because we removed the line in RobotTemplate that initialized the example autonomous command, but we did not get rid of the line that started it.
Unread 01-22-2013, 08:17 AM
AsianRookie AsianRookie is offline
AKA: Steven/Tim
FRC #0321 (Robolancers)
Rookie Year: 2007
AsianRookie is an unknown quantity at this point
is there some code in the teleopInit()?
Unread 02-07-2013, 10:19 AM
carneeki carneeki is offline
AKA: Adam
FRC #3132 (Thunder Down Under), FRC#4774 (LAN Down Under)
Rookie Year: 2010
carneeki is an unknown quantity at this point
Hi salandri_s,
Did you wind up fixing this? If so, could you please post your troubleshooting method? Our team (#4774) is having some trouble finding where the null pointer is creeping in as it doesn't appear in our stack trace either.
Thanks,
Brad
Hi Brad,
Did anybody post any example code to you? If not, I can share our code with you. I'm heading into the workshop in about 7 hours. I will try and strip out everything to see if I can get rid of the exception. If I have no luck, I'll create a Gist and share the link.
FRC-3132 - Thunder Down Under - Mentor since 2011
FRC-4774 - LAN Down Under - Mentor since 2013
VK2JSI... Adam
Unread 02-07-2013, 03:45 PM
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Originally Posted by carneeki View Post
Hi salandri_s,
Hi Brad,
The person above you was correct, you started a command that was not initialized. This throws a NetworkTable error because the commands use NetworkTable to put buttons on the driverstation/dashboard
Unread 02-07-2013, 04:37 PM
AKA: Brad
We found a bug in the C++ and Java libraries where doing a putData() of the Scheduler instance will cause the program to crash. That has been fixed and will be released later today or tomorrow morning.
So if you have code like this:
SmartDashboard.putData(Scheduler.getInstance())
it will be fixed in that update.
Sorry about the annoyance.
Brad
Brad Miller
Unread 02-07-2013, 04:57 PM
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
Brad
Didn't know you could do that
Unread 02-07-2013, 06:58 PM
AKA: Brad
You can do that,
and the update just got pushed out. Look for it in Netbeans.
Brad
Brad Miller
  #15   Spotlight this post!
Unread 02-07-2013, 07:04 PM
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
You can do that,
Brad
How? "Check For Updates" is empty
