Go to Post I need a This-Is-What-I-Meant checker. - N7UJJ [more]
Unread 17-01-2013, 10:04
integr8 integr8 is offline
FRC #1307
integr8 is an unknown quantity at this point
cRIO connection issue-can't deploy code
We are using labview to program our robot and our code looks like it works and no issues are detected when we build the code, but when we try to deploy the code the dialogue box comes up and says:
>>Initializing...
>>Calculating Dependencies...
>>Checking items for conflicts. This operation could take a while...
>>Waiting for Real-Time target (RT CompactRIO Target) to respond
At this point a new box comes up with this error:
>>Failed to connect to real time target
and gives me only one option to cancel.
When I do it says:
>>Current Operation Cancelled
I don't know what the problem is though. We've tried doing something with the network, but when we ping the ip of the cRIO it says that it's connected. We also don't believe it is a hardware issue so any help would be appreciated.
Unread 17-01-2013, 10:14
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: cRIO connection issue-can't deploy code
Have you verified that you have the correct IP address set in the Project Explorer window in labview? It should that 10.17.18.2 (insert your team number in place of 17.18). If it sawys 10.XX.XX.2, you haven't configured it for your project.
Unread 17-01-2013, 10:20
FRC #1307
Yes we have checked that and it says 10.13.7.2
Unread 17-01-2013, 10:22
Jasmine Zhou Jasmine Zhou is offline
FRC #1678
Rookie Year: 2012
Jasmine Zhou has much to be proud ofJasmine Zhou has much to be proud ofJasmine Zhou has much to be proud ofJasmine Zhou has much to be proud ofJasmine Zhou has much to be proud ofJasmine Zhou has much to be proud ofJasmine Zhou has much to be proud ofJasmine Zhou has much to be proud of
Is the firewall on your computer disabled? If not, try turning it off. We had problems last year with connecting to the cRIO, but we use C++ so yours might be a labview-specific issue.
Unread 17-01-2013, 10:34
FRC #1307
We just tried your solution, Jasmine, and we got the same result as before.
Unread 17-01-2013, 10:48
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
When you reimaged your cRIO this year, did you choose the LabVIEW option?
Unread 17-01-2013, 10:57
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Have you verified the IP address on your computer is 10.13.7.5? What is your subnet mask set to?
Connected wired first, make sure your wireless and IPv6 are turned off.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 17-01-2013, 11:09
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Things to try, some of them already mentioned:
  • Disable all other Network connections leaving only the one you are using for the cRIO.
  • Turn off all firewalls and anti-virus programs
  • Verify the remaining connection has an FRC valid IP address, i.e., 10.13.7.5 (for Ethernet) or 10.13.7.9 (for wireless), Check the Advanced button for multiple IP addresses and delete any extras.
  • Start the Driver Station to see the Diagnostic tab ping verifications
  • Try connecting your laptop directly to the cRIO vis Ethernet cable
  • Type ipconfig /all in a command window to verify what your network connections are.
  • Close the Dashboard if it is open and reboot the cRIO. There is currently an issue if the Dashboard is trading data with an existing program on the cRIO.
Last edited by Mark McLeod : 18-01-2013 at 10:46. Reason: Corrected Alan's comment
Unread 17-01-2013, 11:26
Software Architect
The "Failed to connect to real time target" error suggests either a network problem or a misconfigured cRIO. If you can ping the 10.13.7.2 address, the network is probably okay, but you should double-check by using the ipconfig command. Can you copy and paste the results of ipconfig /all here so we can help you narrow down the problem?
Originally Posted by Mark McLeod View Post
  • Close the Dashboard if it is open, then reboot the cRIO. There is an issue if the Dashboard is trading data with an existing program on the cRIO-the traffic volume can drown out the file transfer.
The issue isn't the volume of data being transferred. It's a bug in the Network Tables server that keeps the cRIO program from being terminated when there's a current client connection. Closing the Dashboard is the suggested workaround until a software update is released. Rebooting the cRIO is not necessary.
Unread 17-01-2013, 12:52
FRC #1307
When I pinged ipconfig/all this is what came up
Windows IP Configuration
Host Name: (my name)
Primary Dns Suffixblank)
Node Type: Hybrid
IP Routing Enabled: No
WINS Proxy Enabled: No
Ethernet adapter Ethernet:
Connection-specific DNS Suffix: (blank)
Description: Realtek PCIe GBE Family Controller
Physical Address: 08-2E-5F-7B-6B-38
DHCP Enabled: No
Autoconfiguration Enabled: Yes
Link-local Ipv6 Address: fe80::dc16:faef:92f9:7b3d%12(Preferred)
IPv4 Address: 10.13.7.5 (Preferred)
Subnet Mask: 255.255.255.0
Default Gateway: 10.13.7.4
DHCPv6 IAID: 25219439
DHCPv6 Client DUID: 00-01-00-01-18-4a-43-38-08-2E-5F-7B-6B-38
Dns Server:
fec0:0:0:fff::1%1
fec0:0:0:fff::2%1
fec0:0:0:fff::3%1
NetBIOS over Tcpip: Enabled
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Media State: Media disconnected
Connection-specific DNS Suffix: (Blank)
Description: Teredo Tunneling Pseudo-Interface
Physical Address: 00-00-00-00-00-00-00-E0
DHCP Enabled: No
Autconfiguraton Enabled: Yes
Tunnel Adapter isatap.{A66FC120-4B59-4ABA-A50D-275EF46A6B6B}:
Connection-specific DNS Suffix (blank)
Description: Microsoft ISATAP Adapter #4
DHCP Enabled: No
Autocnfiguration Enabled: Yes
Unread 17-01-2013, 12:58
Just Itinerant
You probably want to turn IPv6 service off.
Unread 17-01-2013, 13:07
Software Architect
I suspect you didn't actually copy and paste that, because there are misspelled words and inconsistent lines, but I'll trust that the content accurately reflects what you got.
With the possible exception of the IPv6 support, everything looks the way I'd expect it to for a properly-configured system. The next step in my troubleshooting script is to verify that the cRIO is correctly imaged. Run the 2013 cRIO Imaging Tool and tell us what it says (a screen capture would be helpful).
Unread 18-01-2013, 09:47
FRC #1307
We turned off IPv6 and ran the cRIO imaging tool and an error message came up that said:
"No CompactRIO Devices were found
Verify an Ethernet connection between the CompactRIO device and the computer, and then turn Windows Firewall Off while imaging the CompactRIO device."
The windows firewall is off but I'm not sure if the computer is connected correctly to the cRIO.
Unread 18-01-2013, 10:06
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
DHCP Enabled: No
Dns Server:
fec0:0:0:fff::1%1
fec0:0:0:fff::2%1
fec0:0:0:fff::3%1
Check the items I bolded. If you disabled IPv6 why is it still showing up in ipconfig /all?
You can try the troubleshooting information in this document.
Try setting your network config back to default and startover, following the instructions in the above document. You may have inadvertently changed something.
Troubleshooting cRIO Imaging
If the cRIO Imaging Tool is unable to locate the cRIO, or a Timout error message is displayed during cRIO Imaging, the issue is likely with the network configuration. One or more of the following steps may be necessary in order to image your cRIO:
Disable all other Network Adapters on the computer. Open the Network Connections window from the Control Panel (see Network Adapter Properties step above), then for each adapter other than the Local Area Connection you are using to image the cRIO, right-click on the adapter and select Disable.
Try using a network switch between the cRIO and computer: Some computers have issues reconnecting to the cRIO after the cRIO reboots as part of the imaging process. Placing a switch between the two devices, such as the D-Link DAP-1522 provided in the Kit of Parts typically mitigates this problem.
Disable Windows Firewall: Windows Firewall may be blocking the cRIO Imaging Tool, preventing it from detecting the cRIO. If possible, temporarily disable the Firewall by going to Start > Control Panel > System and Security > Windows Firewall > Turn Windows Firewall on or off. If the Firewall cannot be disabled, make sure that the FRC cRIO Imaging Tool is allowed through by selecting Allow a program or feature through Windows Firewall from the Windows Firewall screen, then click Change Settings and make sure that FRC CRIO Imaging Tool is listed and has a checkmark for all three network locations. If it is not listed you will have to add it using the Allow another program... button and browsing to the imaging tool location C:\Program Files\National Instruments\LabVIEW 2012\project\CRIO Tool
Try a different PC: If none of the above steps work, try using a different computer to image the cRIO.
  #15   Spotlight this post!
Unread 18-01-2013, 11:24
FRC #1307
We were able to successfully connect to and reimage the cRIO but now when we deploy the code we get a new error. It says:
"Access denied: This target is running a version of LabVIEW Real-Time that is different than the Real-Time Module software on the host computer. You can verify the version and reinstall the Real-Time software using Measurement & Automation Explorer."
Any advice is appreciated.
