Re: cRIO connection issue-can't deploy code
First, reopen your imaging tool and verify that it says that the cRIO's current image is 47.
Next, verify that you've installed the labview updates from usfirst.org (Including the bridge configurator, I believe there are 4 total). |
I have just changed the IP from 10.13.7.10 to 10.13.7.5 and out subnet mask is set to 255.0.0.0 and the default gateway is set to 10.13.7.4. I have also just turned off the IPv6. We are still getting the same issue but now we no longer have communications or robot code in the frc driver station.
Also we are connected directly to the cRIO via Ethernet cable if that makes a difference. |
I just want to ensure that your wireless adapter is disabled or at least not connected to a network. Also set your subnet mask to 255.255.255.0 for programming.
