Go to Post It's like FIRST saying "Well it was too hard, so we give up. Lets give the kids something easier to do." How is that supposed to inspire kids? - Mike [more]
Unread 01-17-2013, 10:07 AM
chi-town-biker chi-town-biker is offline
FRC #3135 (Robotic Colonels)
Rookie Year: 2011
chi-town-biker is an unknown quantity at this point
Safely removing a level three climber
I’ve started planning how we will remove our robot from the pyramid after a level three climb. The robot will be over five feet from the floor and the top close to eight feet. We’re trying to keep the weight down but with battery and bumpers I expect we’ll approach 100 pounds. For testing and practice at school, we’re planning to use an engine hoist or gantry to lift the robot, roll away from the pyramid and lower it to the floor.
I’m less confident about our plan at competitions where special tools are not allowed and the belay system cannot be used for lifting the robot. Here is the procedure I’ve come up with so far.
1) Attach the belay system
2) Turn off the robot
3) Release the pressure on the pneumatic lines
4) Have two students stand between the second and third horizontal bars and lift the robot off the pyramid using secure handles made for lifting
5) The first two students hand the robot to the next two students who are standing between the first and second horizontal bars
6) The second pair of students hold the robot while the first pair climbs outside the pyramid
7) The second pair hand the robot to the first pair who set it on the floor
8) Detach the belay system and carry the robot off the field
In addition to safety glasses, we’re going to issue hard hats to the four students.
I’m mostly concerned about safely handing the robot from the first pair to the second pair. 100 pounds is a significant weight to handle overhead while constrained between a set of bars. Rather than lifting handles, a stout bar that can be grasped along the whole side of the robot may be better even if it is heavier. I hope others have considered this problem and I’m asking for suggestions on how we can improve our procedure.
As an aside, I do think a safer solution at competitions is for FIRST to provide a rolling engine hoist or gantry to teams. The gantry can be used to carry the weight of the robot, roll away from the pyramid, and lower the robot to the floor. Harbor Freight sells a gantry that is over 12 feet high for $650.
Unread 01-17-2013, 11:38 AM
ferret_guy ferret_guy is offline
AKA: Mark Omo
FRC #1703 (RATS)
Team Role: Leadership
ferret_guy is on a distinguished road
Re: Safely removing a level three climber
I believe (I say this because all I have seen is from the field tour videos) that they are using the belay system to lower the robot so it would look somthing like this,
1) connect the belay system
2) release the pressure in the pneumatic system
3) Lower using the belay system
4) remove from field
But I agree with you that hard hats might be a very good thing to use
Unread 01-17-2013, 11:44 AM
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
The gantry system assumes that robots climb the outside of the pyramid ...
Hi!
Unread 01-17-2013, 11:47 AM
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Check this Q&A:
https://frc-qa.usfirst.org/Question/...fter-the-match
Q. May the belay system be used to lift the ROBOT a small distance to aid in releasing it from the PYRAMID before lowering the ROBOT after the MATCH?
A. No. The belay system is meant as a safety against falling ROBOTS, not a removal tool.
The belay system will not be used to lower the robot.
That said, the best way to lower the robot will likely not be between the bars. Stay either inside or outside the entire time, and if you end up inside, roll it out past the bars after its on the ground.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 01-17-2013, 11:54 AM
Rookie Year: 2011
The gantry could lower to the floor inside the pyramid and the students could push/carry the robot out. But to a wider point, removing a level three inside climber is safer than removing an outside climber.
Unread 01-17-2013, 12:11 PM
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Originally Posted by Jon Stratis View Post
Check this Q&A:
Actually that Q&A said that it can't be used to LIFT the robot a small distance, (think like a hook wrapped on the pole, it would need to go up before going down)
The point of the belay system is to keep everything safe, in the event a student can't hold the 150 pounds of robot above their heads.
Why the belay system can't be used to help mitigate the risk of dropping a robot on a student? Beyond me.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 01-17-2013, 12:48 PM
Natchez Natchez is offline
#0118 (Robonauts)
Natchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond repute
FIRST things FIRST ..... please explain how your robot gets to level three? If you would PLEASE post detail drawings and maybe some CAD models, this will certainly help us develop a safe plan for removal of your robot and our 'NEW' robot.
JUST JOKING ..... our robot is still sitting on the floor .... we hope to have the same safety concern one day .... thanks for making us think ahead and DREAM ,
Lucien
Unread 01-17-2013, 12:55 PM
Taylor's Avatar
AKA: @taylorstem
Team Role: Teacher
Originally Posted by Natchez View Post
FIRST things FIRST ..... please explain how your robot get to level three? If you would PLEASE post detail drawings and maybe some CAD models, this will certainly help us develop a safe plan for removal of your robot and our 'NEW' robot.
Lucien
Waaaaaaaiiiit ... Just a minute ... You're a Robonaut, right?
You've been done for three days. The reveal video is probably on youtube somewhere.
Oh wait it is.
Hi!
Unread 01-17-2013, 03:14 PM
Bob Steele's Avatar
Bob Steele Bob Steele is offline
On the RIBMEATS bandwagon....
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
We are going to be working with a trainer to figure out the best way to get our robot down. It will be practiced... we (like all teams) want to be safe
i would also add steel toed shoes/boots to your retrieval people. It might look funny but it works.
Hard hats are ok but I would be more worried about dropping the robot on a foot/feet.
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 01-17-2013, 06:00 PM
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
It is used to keep robots from falling on students. A staff member lets the rope out as you lower the robot by hand. If you somehow drop the robot, the staff member stops letting the rope out, and your robot is stopped before it can fall more than a few inches and significantly hurt people, the field, other robots or itself. One of FIRST's rules is that event staff touches teams' robots as little as possible, so they can't be held responsible as little if something gets broken.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 01-18-2013, 12:03 AM
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
Right, I wasn't very clear.
I meant why not just use the belay system entirely, have the team attach the belay ropes and then the staff member gently lets it down, instead of having to require the students to manhandle it down.
1771- Mentor (2015)
Unread 01-18-2013, 02:44 AM
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
It says that you must use the FIRST belay line, but couldn't you potentially have a belay line of your own hooked up as well and lower it that way? You would need some climbing rope, a few carabiners, a belay device, and a climbing harness and one person could lower it. Just a thought... Would that be legal?
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
Unread 01-18-2013, 02:57 AM
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
In short, no. You can't bring any extra equipment on to the field (like ladders) in order to remove your robot...
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 01-18-2013, 08:06 AM
Rookie Year: 2011
The game manual and the Q&A are clear--no special equipment and teams cannot use FIRST's belay system to lower the robot.
So far, no one has suggested how to remove an outside climbing robot except by handing the robot from one student to another like a bucket brigade.
  #15   Spotlight this post!
Unread 01-18-2013, 09:21 AM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
So I guess a short drive team is out if you are trying for level 3 climb.
Rule G2 prevents teams from climbing on the pyramid. So teams will have to remove the robot while standing on the ground?
