Go to Post Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking. Raul - Raul [more]
Unread 17-01-2013, 17:20
programmerB programmerB is offline
FRC #0968
programmerB is an unknown quantity at this point
Need some help here
Hello everyone i need some help right now. I am trying to figure out how to put some code i made in into a workspace so i can deploy it into the cRio but i can't figure how. please someone advise me what to do
Unread 17-01-2013, 23:04
Adamc4's Avatar
Adamc4 Adamc4 is offline
AKA: Adam Crandall
FRC #3145 (Teraviks)
Rookie Year: 2012
Adamc4 is an unknown quantity at this point
Re: Need some help here
Are you using WindRiver as a workspace to to write your code? Or do you mean you have problems deploying code from your workspace? Please clarify
RoDeL!!!!
Autodesk Oregon Regional Finalists 2013
Spokane Regional Finalists 2013
Creativity and Industrial Design Award 2013
Unread 18-01-2013, 11:10
mprasolov's Avatar
mprasolov mprasolov is offline
Jack of all trades
AKA: Misha Prasolov
FRC #2823 (The Automatons)
Team Role: Student
Rookie Year: 2012
mprasolov is an unknown quantity at this point
Make sure that you start the example project by opening Wind River and got to File->New->Example... Then double-click VxWorks Downloadable Kernel Module Sample Project, then double-click FRC Simple Robot Template. Once you have your code in here, you go to Window->Preferences. Click on FIRST Downloader Preferences. Enter your team #, and navigate to your .out file, which is most likely located in
Code:
C:\WindRiver\workspace\SimpleTemplate\PPC603gnu\SimpleTemplate\Debug\SimpleTemplate.out
Now build (if you haven't already) and the go to FIRST-> Deploy.
Hope this helps
Unread 18-01-2013, 16:54
FRC #0968
i am using windriver as a workspace
Unread 18-01-2013, 19:51
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
Check out this page and see if it helps:
http://wpilib.screenstepslive.com/s/...ct-to-the-crio
Brad
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
