Go to Post ALL technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function. - kmcclary [more]
Unread 18-01-2013, 03:48
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
VEX Pro vs. AM Bearings
So today after hours of milling out our chassis rails I noticed something when I was assembling them. Unfortunately the bearings bought from VEX Pro were not to the quality I would have liked. So heres what I noticed. 1. The VEX bearings were not stamped HEX leading me to think that the bearing was broached by VEX unlike AndyMarks which is stamped FR8-ZZ now I dont know whether this is done by the manufacturer so I cant say exactly. 2. The bore/ inner ring on the AndyMark bearings look larger than the ones on the VEX Pro one. 3. when the bearing were press fitted in our Gearbox to take a hex output if would stick in one place./ when press fitted into our chassis rails and bearing blocks the fit was tight and when it did fit the would be wobble in the sprockets and wheel hubs seen in this video https://www.youtube.com/watch?v=EmbLamJat6o (I have about 10 AM Bearings and 34 VEX Pro bearings. Tried them all in different combinations) I'm not saying the VEX Pro parts are bad but just that the fit of the bearings weren't good enough for us. Just a heads up for teams and VEX.
Unread 18-01-2013, 03:53
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Governors)
Team Role: Coach
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
Re: VEX Pro vs. AM Bearings
My team and I can confirm this. I have played around with a few of jsasaki's VEX and AM bearings, the Hex VEX bearings are not centered. All other components that I've played with from vex are of excellent quality.
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST BAE Systems Hawaii Regional
Unread 18-01-2013, 05:05
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
The runout of an R8 bearing is supposed to be several ten-thousandths of an inch, even for ordinary ABEC 1 or ABEC 3 bearings. Your bearings are visibly out of spec by about two orders of magnitude.
You've clearly demonstrated that those particular parts are bad in any conventional bearing application. Since the parts came that way, I'm sure IFI will be happy to speak with you about it. Hopefully their supplier will also be willing to speak to IFI about it.
(Incidentally, the shields upon which the part number is stamped are a standard part; perhaps IFI didn't want to go to the extra expense of having a custom marking put on.)
Unread 18-01-2013, 05:53
jsasaki's Avatar
AKA: Jun Sasaki
Heres a video of AndyMark bearings https://www.youtube.com/watch?v=_yZm6RUQ92U notice that these bearings dont shift around like this video at 0:27
Unread 18-01-2013, 07:41
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
I would definitely be contacting IFI and speaking to them. I'm sure they are going to want to know this, so that they can go back to their supplier/Manufacturer.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 18-01-2013, 07:42
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
So I have a few questions from the video and I can clear up some of your assumptions.
First, the bearings are not broached by VEX afterwords. They are broached by the bearing manufacturer prior to hardening and grinding.
Second, the first shot in the first video I don't really know your setup so I can't comment on the wobble. In the second shot are you saying there is wobble in that video? In any case , please contact customer support and we can get you replacement bearings. Please be sure to give them your order number.
Third, the shield is a completely different part from inner race and we used a standard fr88 bearing shield.
Last, the absolute best way to get customer support from VEX is to call the support line or email support@vexrobotics.com
I assure you that the bearings are supposed to be ABEC1 and not have wobble like you show on your video. We use these same bearings in our single speed gearboxes and we do not see this issue.
Please contact customer support and we can resolve this issue.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 18-01-2013, 07:45
MichaelBick MichaelBick is online now
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
Is this on all vex bearings or just the ones that have a hex?
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 18-01-2013, 08:19
Rookie Year: 2000
What question are you asking and who are you asking?
Unread 18-01-2013, 08:43
Rookie Year: 2010
Hi Paul, sorry for being unclear. We ordered a lot of bearings from Vex this year(FR8-ZZ Hex, FR8-ZZ, FR6-ZZ Hex, FR6-ZZ). This obviously is an unusual problem, but I was wondering if any other teams have found runout problems with their other bearings(specifically the ones we ordered). We haven't recieved our Vex order yet so I want to be prepared to check our bearings for any runout.
Unread 18-01-2013, 08:58
Andrew Lawrence
Posts: n/a
In our recent tests with non-hex bearings, VersaWheels, and a perfectly circular axle, the wheel, when turned, moved perfectly straight with no wobble to either side, and the bearings worked as expected.
Unread 18-01-2013, 09:12
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
For various reasons we've gotten .5" hex bearings from both VEXPro (80) and AndyMark (60) , and haven't noticed a problem with either.
I'm sure that the occasional bearing has a problem -- this happens with any large-quantity manufactured good -- but thus far the quality control of both products seems to be quite satisfactory.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 18-01-2013, 10:03
jsasaki's Avatar
AKA: Jun Sasaki
Thanks for the reply Paul. Definitely will contact VEX asap. I just want to clear up with you that the VEX Pro bearings were in fact not concentric as you can see in this video at 0:27. I'm just hoping it was a small batch error but no matter what setup the bearings are in, it just wont work.
Unread 18-01-2013, 10:06
jsasaki's Avatar
AKA: Jun Sasaki
We only purchased half inch hex bearings from VEX
Unread 18-01-2013, 10:56
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
I would be interested in more details.
Did the VEX bearing stick before you pressed it in your bore? If not, it's possible (if not probable) that your bore could be too tight, or you pressed it in and indented the shield, or somehow damaged the race/ball interface.
Did you try an AndyMark bearing in the same bores that you displayed the runout in your first shot? Did you independently chuck the shaft and hub in a lathe/drill press/something else that spins to verify that each component spins true? Without all 3 of those actions, there's no way of isolating the problem to your bearing.
2001-2004: Team 100
2006-Present: Team 254
  #15   Spotlight this post!
Unread 18-01-2013, 11:04
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
I'm sure Paul and his staff at VEXPro will get to the bottom of this.
Just because I am addicted to looking at details, I took a two VEXPro FR8ZZ Hex bearings (217-2734) to my lab and set up an indicator to measure run-out while the bearings were supported by a hex shaft clamped in a bench vise. They measured 0.0005" TIR on the outer race and 0.0015" TIR on the inner flange face. I have some AndyMark FR8ZZ Hex bearings (am-0279) on order and will test a couple of them the same way when they arrive.
Richard Wallace
since 2003
