Dashboard doesn't load with the Drivers station
We was having trouble getting the dashboard to run when we log into the driver account on the classmate. The driver station lower part comes up, but the upper dashboard does come up. I can run the dashboard from the c:\Program Files\FRC Dashboard\Dashboard, but it doesn't come up when I come in. I was wondering if anyone else was having the same problem, or had any idea how to get the dashboard to load when we log into the driver account.
Re: Dashboard doesn't load with the Drivers station
Check on the Driver Station Setup tab to see if Local Dashboard is selected.
If that isn't it, then take a look in: C:\\Users\Public\Public Documents\FRC\FRC DS Data Storage.iniLook for these lines and check that the Dashboard path is correct: DashboardLocal = TRUE |
Also, on the setup tab, make sure that the Default option is chosen for Dashboard Type.
