Values for Image Proccessing
Hello,
I'm trying to determine what values to replace the ones in the following line with. BinaryImage thresholdImage = image.thresholdHSV(60, 100, 90, 255, 20, 255); Any help would be appreciated. We have never used vision processing before this year as a team and have decided to go with a green ring light. |
Re: Values for Image Proccessing
10,60,200,255,200,255 though this is our specific test field and im currently working on a system to adjust for light |
How did you determine what values to use for your system?
You should use the NI Vision Assistant to experiment with the numbers. You can see the results of the changes immediately on the screen. If you've installed the NI FRC tools on your computer, you should have it.
Start it up, choose "Acquire Image", choose "Axis Camera", fill in the IP info, and click the play button and you'll see your camera feed. If you click the single play button it will take a snapshot. Then click the last icon to "store the acquired image in browser". Then go to the Process Images page, choose the Color Threshold tool, select HSV, and then you can tweak the numbers there and see exactly what it would do to your image. You can, of course, add multiple processing filters along with the final particle report - exactly the same as you would in your program. Keep in mind that in Java you don't have access to all the different tools that are shown in the Vision Assistant. Dale |
What range of values should i start out with.
We are using a green ring light as mentioned before |
Is it likely that there will be noise/small particles that stray after the threshold is done.
Have you read the Vision Processing paper? http://wpilib.screenstepslive.com/s/3120/m/8731
Yes i have read the linked document but could not find much info on the threshold values
Without seeing your images, I'd say you should probably start with maxH higher, say at 125 or so. You should also lower minH from90 to 40 or so. Then work the mins higher and the MaxH higher until you eliminate other particles. Greg McKaskle |
#10
Which tool in vision assistant should i use for testing and finding the values
#11
In NI Vision Assistant, load the sample script they give you.
Acquire an image by connecting to your camera and using the Acquire Image button (enter IP and settings). In the Color Threshold, adjust the values until your goal is red (and nothing else is). Those are your HSV values that you want to put into your program. |
#12
Yeah that's what I thought too at first, but apparently not. The red part is what you want.
Ideally you'd see a border of red around some black (goal hole), then everything else is black. Then, if you go down the steps (beyond the color threshold), you should see the goal get entirely filled in with red, and the small particles get eliminated. Here: http://wpilib.screenstepslive.com/s/...ng-the-targets RTFM (Read The FIRST Manual) ![]() |
#14
Oh i get what your saying i was think of it in terms of the preview color when applying the threshold in vision assistant not as the image afterwards
#15
Yeah it's our first year doing image processing too.
We also had some problems with the provided sample code (java) detecting distance, so we're in the process of writing our own distance computing method. |
