Go to Post Here we go again with all kinds of speculation. We can never out guess FIRST. - BobC [more]
Unread 19-01-2013, 07:07
ohrly?'s Avatar
ohrly? ohrly? is offline
Griffin Alum
AKA: Colin Poler
FRC #1884 (The Griffins)
Rookie Year: 2011
ohrly? is an unknown quantity at this point
Attaching things to belt
Anyone know an effective way to attach sheet metal to a belt [standard kitbot belt]?
The belt would need to go all the way around the pulley.
I was thinking we sew it on? Or superglue it?
Unread 19-01-2013, 09:10
CalTran's Avatar
CalTran CalTran is online now
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: Attaching things to belt
Good luck sewing through kevlar reinforced belts, and super glue will probably rip right out. There's a thread somewhere on here recently that asked the same question. They weRe referred to using some chains and special links
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 19-01-2013, 09:56
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
http://www.mcmaster.com/#roller-chain-attachments/
with roller chain will be much easier than trying to attach things to belts.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 19-01-2013, 11:59
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Actually, I think those two things can be made to work, though it will depend on the exact application and the thing being attached.
With a commercial sewing machine (like an upholstery machine), you can probably pierce thin aluminum sheet metal (less than 0.020 in) and sew it right through the belt. (You can also pre-punch thicker metal.) You can probably find Kevlar or Spectra thread.
Also, several types of belts are designed to be welded with a high quality ethyl cyanoacrylate superglue (Loctite 404, for example), which may also bond adequately to metal. Watch out for flexing the joint too much, though. Even if the glue survives, you may overstress the substrate.
In both cases, to get it to go around a pulley, you may have to attach it with a single line across the width of the belt. Carefully consider the engineering of this system, because it sounds like it's inherently kind of fragile. Chain may ultimately be easier: see here for more ideas about attachment chain.
Unread 19-01-2013, 12:08
d.kho's Avatar
d.kho d.kho is offline
AKA: Daniel Kho
FRC #2473 (CHSR)
Team Role: Leadership
Rookie Year: 2012
d.kho is an unknown quantity at this point
We're using the chain too, but duct tape works really well in a pinch with the belts. Since when did it not? (We've actually tried it.)
