Go to Post Honesty and Integrity is the key to success. - team4384 [more]
Unread 19-01-2013, 10:08
V.M.Santore V.M.Santore is offline
FRC #0204
V.M.Santore is an unknown quantity at this point
Motors Per Motor Control
Does every motor have to have a dedicated motor control, such as a jaguar, or can multiple motors use one motor control?
Unread 19-01-2013, 10:13
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Motors Per Motor Control
Usually one motor per motor controller, especially for the larger motors.
See R52 for exceptions on the smaller motors (less than 100w max power).
Unread 19-01-2013, 10:27
FRC #0204
Thanks!
Unread 19-01-2013, 21:44
jmiller18 jmiller18 is offline
FRC #2429
jmiller18 is an unknown quantity at this point
At the LA regional in either 2010 or 2011, one team used two motors on one victor this caused it to flame for a few seconds. They were able to repair the robot and renamed it the phoenix. That should answer your question.
Unread 19-01-2013, 23:37
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
No rules prior to 2013 allowed more than one motor per speed controller.
See Table 4-4 for a complete listing.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 20-01-2013, 11:26
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
Rookie Year: 2011
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
However, keep in mind that this does not mean you cannot connect multiple drives to the same PWM signals using a Y cable. On many types of drives this can be a very good idea to insure that the drives stay in sync, and do not fight each other.
This is the zeroth day of the rest of your life.
Unread 20-01-2013, 11:59
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Assuming the controllers react to inputs the same way. (Otherwise known as being calibrated properly.)
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 20-01-2013, 12:11
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
For smaller motors, they will be just fine under a single control (and this is legal now, finally).
Example:
The combined stall current of 2x window motors on a Talon is well below the continuous current spec of the Talon and on a 40a breaker it will be impossible to trip (the PTC in the motors will trip first). We wired our 2011 practice robot using 1x Victor, using 2x Victors and a Y-cable on the competition bot.
Don't put two large motors like CIM's on a speed controller and expect it to live, though (although the 40a breaker *should* trip first).
Y-cables are also highly recommended whenever two motors do the same thing. Our 2012 robot in it's final state had 16 speed controllers (14x Victor 2x Vex) and 2 servos on a single digital module and sidecar, all made possible with Y-cables.
Kettering Motorsports
Unread 21-01-2013, 07:29
Unsung FIRST Hero
Rookie Year: 1996
Just to clear up some confusion...
The snap action breakers trip on over current but reset almost immediately. When really over stressed, they will actually buzz. Be careful, once the buzzing starts, the heat begins to rise. These little devices have been known to leave marks on the unwary.
Al
WB9UVJ
www.wildstang.org
Unread 21-01-2013, 09:47
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Where did you get this 100W limit? I don't see that in the manual. Note that (as Al said), Table 4-4 has an explicit list of what motors can share one controller. Not all motors under 100W (or even 50W) can share a controller. The biggest one, the BaneBots MS-RS775-12, is 83W, so the total would be 166W if you want to put two of those on a controller.
Personally, I would only put two matched motors on one controller, and preferably when they're driving one load (e.g. one shaft). So, two window motors might make sense on one controller.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 21-01-2013, 09:48
Unsung FIRST Hero
Rookie Year: 1996
Gerry,
He wasn't quoting a rule, just grouping the motors by output power.
Al
WB9UVJ
www.wildstang.org
Unread 21-01-2013, 10:06
AKA: Gerry
Originally Posted by Al Skierkiewicz View Post
Gerry,
I see. I'm not sure the snow blower motor is included in the motors allowed to share, and it's only 30W. I haven't looked at a snow blower motor closely, but judging from the picture, I think it's a worm drive, so it wouldn't count in the "am PG motor" group. I could be wrong (wouldn't be the first time).
Cal
Fairport, NY, USA
Unread 21-01-2013, 10:32
Unsung FIRST Hero
Rookie Year: 1996
Gerry,
This question is currently on the Q&A
Al
WB9UVJ
www.wildstang.org
Unread 21-01-2013, 10:51
AKA: Gerry
Ok, I just looked at that Q&A (Q274, answer still pending as I write). It's interesting, but to me just academic. We're only allowed to use one snow blower motor, and I wouldn't put mismatched motors on one controller, so the answer won't make any difference to our team. If we use a snow blower motor at all, we'll treat it as a one-motor-per-controller device.
Cal
Fairport, NY, USA
  #15   Spotlight this post!
Unread 21-01-2013, 11:19
Unsung FIRST Hero
Rookie Year: 1996
Since you can only have one snow blower motor on the robot, that would be an appropriate choice.
Al
WB9UVJ
www.wildstang.org
