Go to Post That sound you hear is of every programmer in the country cringing at the thought. - Billfred [more]
Unread 19-01-2013, 10:44
jarruda jarruda is offline
Software Engineer
AKA: Justin Arruda
FRC #1350 (Rambots)
jarruda is an unknown quantity at this point
SmartDashboard Won't Start
When attempting to open SmartDashboard (tried 1.0.3 and 1.0.4 installers) from explorer, nothing happens.
When attempting to open from commandline with java -jar Smartdashboard.jar, I get:
Code:
C:\Program Files\SmartDashboard>java -jar SmartDashboard.jar
Searching Folder:.\lib
Searching Folder:.\extensions\lib
Adding Jar:.\extensions\lib\javacpp.jar
Adding Jar:.\extensions\lib\javacv-windows-x86.jar
Adding Jar:.\extensions\lib\javacv.jar
Adding Jar:.\extensions\lib\WPIJavaCV.jar
Adding Jar:.\extensions\SquareTrackingExtension.jar
Adding Jar:.\extensions\WPICameraExtension.jar
Searching Jar:.\extensions\SquareTrackingExtension.jar
Custom Static Widget:Tracker
Searching Jar:.\extensions\WPICameraExtension.jar
Custom Static Widget:WPICameraExtension
Custom Static Widget:WPILaptopCameraExtension
java.lang.reflect.InvocationTargetException
        at java.awt.EventQueue.invokeAndWait(Unknown Source)
        at javax.swing.SwingUtilities.invokeAndWait(Unknown Source)
        at edu.wpi.first.smartdashboard.main.main(main.java:77)
Caused by: java.lang.NoClassDefFoundError: Ledu/wpi/first/wpilibj/networking/NetworkTable;
Caused by: java.lang.ClassNotFoundException: edu.wpi.first.wpilibj.networking.NetworkTable
If I run the dashboard from within the sunspotfrcsdk\lib directory that I installed with Netbeans, it works just fine. I tried adding this directory to my PATH and re-running, but no dice.
Finally, I tried to add all the files in sunspotfrcsdk\lib to SmartDashboard\lib, since it seems to search that directory. Running, I then get:
Code:
Adding Jar:.\lib\networktables-crio.jar
Adding Jar:.\lib\squawk.jar
Adding Jar:.\lib\wpilibj.jar
When looking into the jars that are in those directories, I see NetworkTales located at edu.wpi.first.wpilibj.networktables.* and NOT at edu.wpi.first.wpilibj.networking.* where it is looking for.
What's the deal here? Is SmartDashboard/lib supposed to be empty?
Unread 19-01-2013, 10:58
Software Engineer
AKA: Justin Arruda
FRC #1350 (Rambots)
Update
It appears that I was correct; the lib directory is NOT supposed to be empty.
The 1.0.3 and 1.0.4 installers do not install the necessary libraries to this directory; namely:
  • jcommon-1.0.16.jar
  • jfreechart-1.0.13.jar
  • junit-4.8.2.jar
  • NetworkTable_Client.jar
Installing the last version that named the installer SmartDashboardSetup, 1.0.2 first, then installing 1.0.4 on top of that allows it to work correctly.
I hope this helps someone that runs into the same issue.
Unread 19-01-2013, 11:40
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: SmartDashboard Won't Start
Good job tracking that down. You can file a bug here: http://firstforge.wpi.edu/sf/tracker...d/tracker.bugs (you will need to create a first forge account if you don't already have one).
Unread 19-01-2013, 17:48
mitchellweb1 mitchellweb1 is offline
AKA: Mitchell W
FRC #0190
mitchellweb1 is an unknown quantity at this point
As of 2013 NetworkTables and all other dependencies have actually been bundled inside of SmartDashboard.jar (this allowed for a standalone jar). Is it possible that you were running the SmartDashboard when you ran the installer such that SmartDashboard.jar was not replaced?
