Go to Post In my opinion, if it can light a fire in your heart to burn with passion, and you can maintain that fine line between passionate and crazy; then go for it. Power to Passion. - RKElectricalman [more]
Unread 19-01-2013, 10:57
Reggie335 Reggie335 is offline
AKA: Reginald
FRC #4297 (WeNoRobots)
Team Role: Leadership
Rookie Year: 2011
Reggie335 is an unknown quantity at this point
Can we Cut Down ToughBox Nano?????
Can We?????????
Unread 19-01-2013, 10:59
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Can we Cut Down ToughBox Nano?????
I guess that depends on whether or not you have a hack saw?
If you're wondering whether or not it's allowed, read the rules, see if there's anything prohibiting you from modifying drivetrain parts other than motors. I don't recall seeing anything, but I admit I didn't read the rules well enough to know for sure, either.
Unread 19-01-2013, 11:22
AKA: Reginald
Rookie Year: 2011
We Have A Hack Saw And the rule Book didn't say anything about it. we was just wondering can we move the gears back. This is what we are using Toughbox Nano Tube 31, Two 500 Key Shafts (am-0688)
Unread 19-01-2013, 11:31
dudefise dudefise is offline
FRC #2637 (Panthers)
Rookie Year: 2011
dudefise is an unknown quantity at this point
This is legal as far as I know.
2010 VRC 2453B - Team Captain
2011 FRC 2637 - Electrical - Las Vegas Regional Semifinalists with 1726 and 166
2012 FRC 2637 - Electronics Captain - Las Vegas Regional Semifinalists with 1661 and 2984
2013 FRC 2637 - Build Captain - Inland Empire Quarterfinalists with 3925 and 207
2014 FRC 2637 - College Mentor - Central Valley Quarterfinalists with 2085 and 5136 / LA Regional Semifinalists with 696 and 5102
2015 FRC 2637 - Lazy Schmuck - Couch Sitting Quarterfinalist
2016 FRC 2637 - College Mentor - SD Regional Finalist with 1572 and 2443, Excellence in Engineering, Wildcard
Unread 19-01-2013, 14:05
I used to work in a body shop, and it was often easier to "chop" stuff in the middle. You try to leave the precision mounting elements alone and take a boring part that was long and make it shorter. If you can find an extrusion that will fit inside or outside of the tube, that will simplify things. You can also try to it using plates to mount to either side and bolt through. There are obviously other ways to rejoin it, and if you have an appropriate sponsor, you may want to ask them first.
This also sounds like one of those times when measure twice and cut once is actually not cautious enough. I'd suggest measuring, marking it up, checking it, AND reviewing it with another person to check your math. Also, remember about your kerfs and that it easier to trim more away than it is to put it back on.
Greg McKaskle
