Go to Post If we can figure out how to make a robot in six weeks, a little thing like personality conflict should be easy to overcome. - Al Skierkiewicz [more]
Unread 19-01-2013, 11:43
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Issue with Toughbox Mini/encoder
I'm hoping we just did something wrong here...
We've got the Toughbox mini from the KoP (http://www.andymark.com/product-p/am-2236.htm) fully assembled, and are attempting to mount some encoders to them (http://www.andymark.com/product-p/am-0180.htm).
We haven't had an issue doing this in the past with the Toughbox or the CIMple boxes... However this year we're putting the disks on the shaft for the encoders, and they're sliding on loosely - it's not a press fit like in the past.
Has anyone else run into this problem? is there something we could have done wrong assembling the gearboxes? Both the gearboxes and the encoders are brand new (the encoders just arrived from AndyMark yesterday).
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 19-01-2013, 12:06
Re: Issue with Toughbox Mini/encoder
FYI... I was looking around on AndyMark's site to see if there was something we missed (like ordering incompatible encoders or something), and came across this page:
http://www.andymark.com/product-p/am-0174.htm
It includes this installation tip:
Installation tip:
If the encoder wheel slides loosely onto the 1/4" shaft, then follow this procedure to make the inside diameter of the encoder wheel collet to be slightly smaller:
Use a medium-sized pair of pliers and gently squeeze the collet portion of the encoder wheel. This is the longer protruding part of the encoder wheel with the parallel slits in the body. If you gently squeeze the sides together, equally, in 2 or 3 different locations, you can make the inside diameter of the encoder wheel slightly smaller. Then, the wheel will fit on the new shaft.
So, we're working on doing that now. I wanted to make sure to post it here incase anyone else has the same problem and comes across this thread!
Unread 24-01-2013, 20:31
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
Thank you, Jon! We discovered this issue and I decided to look on CD first to see if it was a known concern before I went to Andy Mark! You made my job a breeze!
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Unread 24-01-2013, 20:43
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Don't scratch the encoder optical surface.
Unread 24-01-2013, 22:45
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Be very careful. We've had this same problem and some overzealous team members bent the retaining fingers only to find that they are extremely brittle and break very easily!
