Go to Post This is the first (and, if this stuff keeps up, last) time FIRST has allowed high-speed projectiles in years. Please use some common sense, people. - Madison [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 19-01-2013, 11:45
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Using Network Tables
Can I send this line
ColorImage image = camera.getImage()
to a folder on the driver station?
Unread 19-01-2013, 11:53
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
Re: Using Network Tables
NetworkTables doesn't send large data items like images from the robot to the laptop. However, if your goal is to process the image on the driver station computer, you can connect the camera to the switch on your robot and just open it from the laptop. There are several ways of doing that. You can write a program with RoboRealm for doing the image processing. You can write your own program using some library like OpenCV or the NIVision library, or you can make a SmartDashboard plugin that does the image processing.
If you want to do the vision processing on the robot, then there are some sample Java programs for robot-side target detection in NetBeans.
Brad
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 19-01-2013, 14:39
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
e/ Changing the focus of this thread!!
Whenever im using RoboRealms, I can add the Network Table widget to the current setup, set the ip to 10.16.84.2, set the default camera to none, but when i run the program its not going to the axis camera on the robot its booting my webcam!
Options>Video>Camera only has two settings, Nothing and my camera. (default to nothing)
Unread 19-01-2013, 15:09
SuperMario SuperMario is offline
FRC #3692
SuperMario is an unknown quantity at this point
I'm not sure what you are asking, but you can access the ip of the camera and see the feed from any computer.
Unread 19-01-2013, 16:56
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
k, nevermind, thread derail again... (Forgot to add the axis intenet camera module)
how do i instantiate a network table?
cameraTable = NetworkTable.getTable("RoboRealm");
gives me an error
Illegal State Exception : network table already initialized
(if i catch the error, it does nothing)
e/ nevermind.
current problem =
Code:
public void testPeriodic() {
        enabledPeriodic();
        NetworkTable server = NetworkTable.getTable("SmartDashboard");
	try
			System.out.println(server.getNumber("IMAGE_COUNT", -1.0));
	catch (TableKeyNotDefinedException ex)
continually prints -1
my robo builder setup:
Axis_Internet_Camera 10.16.84.11
Threshhold 200-255 (sat)
Fill 500
Convex Hull
set IMAGE_COUNT = /SmartDashboad/IMAGE_COUNT
Network_Tables (port 1765, ip 10.16.84.2, send : IMAGE_COUNT)
Unread 19-01-2013, 17:42
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
Rookie Year: 2012
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
So... is there a way to have the Roborealm server process the Axis camera images, then send those images to the SmartDashboard so that we can see the processed output?
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 19-01-2013, 17:53
mitchellweb1 mitchellweb1 is offline
AKA: Mitchell W
FRC #0190
mitchellweb1 is an unknown quantity at this point
You can try using the TableViewer to ensure that the key that you are expecting is actually in NetworkTables. You can find it in C:/Users/YOURUSERNAME/sunspotfrcsdk/tools/TableViewer-VERSION.jar
This will allow you to connect to a networktables server and view the raw entries.
Unread 19-01-2013, 18:41
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
what. why would you want to do that.
(yes, just have roborealm save to a file than have smartdashboard read to file)
Your right... the entires arent there... but IMAGE_COUNT (in no subfolder) is
Unread 21-01-2013, 14:06
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
bump...
set IMAGE_COUNT = /SmartDashboard/IMAGE_COUNT
in RoboRealm isnt working and it keeps saving to IMAGE_COUNT. What would the proper configuration be for seting IMAGE_COUNT to /SmartDashboard/IMAGE_COUNT OR can i get IMAGE_COUNT from the crio root?
(to rehash the thread)
Unread 21-01-2013, 15:24
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
Rookie Year: 2010
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Originally Posted by Arhowk View Post
bump...
you have to set /SmartDashboard/IMAGE_COUNT = IMAGE_COUNT
The left side is for the variable you are setting. The right is for setting the value of that varaible.
Unread 21-01-2013, 18:02
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
... almost there....
ok i got that. it didnt work. than i sent /SmartDashboard/IMAGE_COUNT and it *almost* worked.
It sent it once. but thats it. it will NOT overwrite the values. it will create them and send them but not overwrite
using Set_Variable, i set GG = 123
i sent GG
TableViewer says GG = 123
i set GG = 234 (in RoboRealm)
i send GG
i make a new variable GG1
i set GG1 = 234
i send GG1
TableViewer says GG1 = 234, GG = 123
Unread 19-01-2013, 16:55
MagiChau's Avatar
AKA: Michael Chau
Rookie Year: 2010
You have to use the AxisCamera module on RoboRealm. That is the only way I know of you are going to get a feed on RoboRealm.
