Go to Post The Robot Alliance Project is perpetrating the government shutdown? I KNEW robots would take over the world! - BBray_T1296 [more]
Unread 19-01-2013, 17:19
theblazefenix theblazefenix is offline
FRC #4096
theblazefenix is an unknown quantity at this point
How do I set up the AXIS webcam?
I am currently trying to set up our team's vision tracking camera. We have the software from NI to set up our Axis camera. It asks to set it up with Robot Radio, or with the CRIO. If we are wanting to program the camera in LabVIEW which should we use. I hear that using LabVIEW, it uses the D-Link.
Unread 19-01-2013, 17:55
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: How do I set up the AXIS webcam?
I can't think of any reason to set up the camera to connect directly to a cRIO. Connect it to the D-Link robot router; it'll end up with an IP address of 10.40.96.11 when configured properly.
Unread 19-01-2013, 18:54
Dinoyan Dinoyan is offline
Team Role: Electrical
Rookie Year: 2012
Dinoyan is an unknown quantity at this point
http://www.usfirst.org/sites/default...20System_2.pdf
Go to page 27
Unread 19-01-2013, 19:49
team3039 team3039 is offline
FRC #3039
team3039 is an unknown quantity at this point
Connect your AXIS Camera to the Computer, using a cross over cable. If you've already tried to configure your AXIS camera, I recommend resetting the AXIS camera by disconnecting power, hold the reset button on the back while you apply power. Release the button when the light around the lens turns amber. Configure your computer ip to 192.168.0.51. Open up the AXIS Setup Tool, select Robot Radio and enter your team name. Your AXIS camera should be configured to 10.40.96.11. Test the connection by opening up the default dashboard, and connect your AXIS camera to the D-Link router.
Feel free to send me a PM if this doesn't work.
Also, I have customized the vision tracking tutorial .vi to work with the dashboard. I recommend doing this as it will take a ton of load off the CPU on the cRIO.
