Go to Post FIRST has a 365 day season (366 on leap years)... - Adam Richards [more]
Unread 20-01-2013, 00:51
GarrettF2395's Avatar
GarrettF2395 GarrettF2395 is offline
Mentor
AKA: Sierra 117
FRC #2395
Team Role: RoboCoach
GarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of light
Send a message via Yahoo to GarrettF2395
Vex VersaHub Hex Alignment
Are we doing this right?
Our team decided 2 hex hubs would be preferred for extra strength/integrity, however, the alignment on 6 of the 16 hubs we ordered do not line up with the hex shaft. We will be contacting Vexpro on Monday to see if we can correct the problem.
I do want to say that everything else we have received from VexPro has been fantastic and I highly recommend their products.
https://twitter.com/TeamNinjaMunkee
FRC 2395: Team captain 2008-2009, Design mentor 2010-2011, Lead design and strategy mentor 2012-Present
Unread 20-01-2013, 00:57
Andrew Zeller's Avatar
Andrew Zeller Andrew Zeller is offline
Mechanical Engineering at UA
FRC #1716 (Redbird Robotics)
Rookie Year: 2010
Andrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura about
Re: Vex VersaHub Hex Alignment
I believe that the VexPro hex hubs are intended to only be used on one side of a wheel, with the other side supported with a hex bearing.
Check out this thread for more details:
http://www.chiefdelphi.com/forums/sh...ex#post1200373
FIRST ROBOTICS TEAM 1716 Redbird Robotics
2012 Wisconsin Regional Judges Award
2012 Wisconsin Regional Quarterfinalists
http://www.frc1716.org/
Unread 20-01-2013, 00:58
Hey Garrett! I believe Paul updated in the other thread that the original intent was for hubs to be aligned, but constraints limited the ability to do this, or some reason of that nature. He said that the other side of the wheels should be supported with a hex bearing.
I can find the post in a bit.
http://www.chiefdelphi.com/forums/sh...&postcount=175
Unread 20-01-2013, 01:10
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
You simply do not need the extra strength. Just use a bearing on the other side to pilot the shaft.
Unread 20-01-2013, 01:13
Mentor
AKA: Sierra 117
FRC #2395
Thanks guys.
Good to know that there is a (cheap) solution to this problem.
Unread 20-01-2013, 07:03
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Governors)
Team Role: Coach
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
Has anyone done testing on the versa wheels/hub for a single hub attachment with no end support?
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST BAE Systems Hawaii Regional
Unread 20-01-2013, 13:35
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
With wheels that can get a knocks and bumps. It better to have all the support you can reasonably get. Especially since you can drop a bearing in the side opposite the hex bore.
Unread 20-01-2013, 17:12
josesantos's Avatar
josesantos josesantos is offline
Mentor; Former Design Chairman
FRC #0687 (Nerd Herd) (VRC #687z) & FRC #5499 (BHS Robotics)
Rookie Year: 2011
josesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond repute
When using the suggested hub-bearing combination for mounting onto a cantilevered drive base like a West Coast Drive, is it ideal to have the hub facing into or away from the robot frame?
Unread 20-01-2013, 17:16
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
We're facing ours away since you put the wheel on bearing side first, then rotate it to line up with the hex hub versus the other way around. Assembly order seems a bit easier like this.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 20-01-2013, 17:34
josesantos's Avatar
Rookie Year: 2011
I hadn't considered that. Thanks!
