Go to Post Not that I'm doubting you, but where is it bugged? The exterminators are in the house. - Greg McKaskle [more]
Unread 20-01-2013, 20:07
Kamal Sadek Kamal Sadek is offline
FRC #0295 (Renevatio)
Rookie Year: 2012
Kamal Sadek is an unknown quantity at this point
Flight Recorder Help
While working with the Java interface for the robot, we found that many of the files were omitted (We were unable to import them). One of these such files is java.io.File, which contains all the information needed to work with files. Is there anyway to work around this?
Unread 20-01-2013, 20:27
vinnie's Avatar
vinnie vinnie is offline
FRC #3309 (Friarbots)
Rookie Year: 2010
vinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond repute
Re: Flight Recorder Help
I'm not near a computer right now so I can't give you exact code but you'll want to use the FileConnection of Java ME. If you Google "j2me file connection" you should be able to find examples.
Student (3309) 2010-2013
Mentor (597) 2014
Mentor (3309) 2013-Present
Unread 20-01-2013, 20:38
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
The version of Java on the robot is Java ME, rather then Java SE that you are used to using on a computer. Java ME is based on Java SE version 1.3, so many new features are not available. Looking specifically for Java ME examples may be helpful.
For examples of reading and writing files, you can look at the Preferences class.
