Go to Post To limit FIRST to robots, tools, and competition is to strip away its immense potential. - Madison [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 20-01-2013, 21:13
2544HCRC's Avatar
2544HCRC 2544HCRC is offline
FRC #2544 (HCRC)
Team Role: Coach
2544HCRC has a spectacular aura about2544HCRC has a spectacular aura about2544HCRC has a spectacular aura about
Exporting inventor so it can be read for CAM
We built a part in Inventor and took it to a supplier so they could produce it on a CNC machine. They could not open the file in their version of Autodesk (not sure what they have). We tried 2 different file types. One was the inventor file. The other was as a dwg file. Also this shop is using version 13? Any suggestions?
Also we are looking at creating parts to be cut on a waterjet. Are we going to run into problems with inventor? We don't have much time invested in any software package and could easily switch if needed.
Unread 20-01-2013, 21:19
WileyB-J's Avatar
WileyB-J WileyB-J is offline
4976 Georgetown Rebels
FRC #4976 (Rebels)
WileyB-J will become famous soon enoughWileyB-J will become famous soon enough
Re: Exporting inventor so it can be read for CAM
Try a .stp, or .step file. Go though the Save As menu to "Save copy as" and find the STEP file convention.
Unread 20-01-2013, 21:20
josesantos's Avatar
josesantos josesantos is offline
Mentor; Former Design Chairman
FRC #0687 (Nerd Herd) (VRC #687z) & FRC #5499 (BHS Robotics)
Rookie Year: 2011
josesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond repute
The computers at a community college I took shop classes at were running an old version of Inventor as well (version 9, I think), so I just converted to STEP whenever I did work from my home computer (which was running Inventor 2011 at the time).
Unread 20-01-2013, 21:23
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Rookie Year: 2010
slijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to behold
Are you saying that the shop is using Autodesk Inventor 2013 and they can't open the files you gave them? What kind of "inventor file" did you provide them with - an assembly or part?
You may be able to transfer the part information using a STEP file, which is a fairly universal format (in the main menu, go to Export).
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 21-01-2013, 14:55
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
STEP files generally resolve any issues with file transfer between different CAD or CNC applications.
Let me know if the machine shop still have problems opening the STEP file you create.
Also, do you know what CNC application they are using?
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 21-01-2013, 15:21
EricPalmatier's Avatar
EricPalmatier EricPalmatier is offline
FRC #0250 (The Dynamos!)
Rookie Year: 2000
EricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to behold
Send a message via AIM to EricPalmatier
Hey. Feel free to try the following. It has always worked for me, though your software and/or experience may differ.
Step one: open .ipt in inventor and export as a .dwg.
Step two: open .dwg into autocad
Step three: use the flatshot command to flatten the geometry. Basically gives you a 2d version of your 3d drawing
Step four: save file as a .dfg
Step five: open .dfg into your CAM software and assign tool paths
Step six: print out part on CNC
These steps generally work for me. Let me know if you try it and it works/ doesn't work.! Ill find out what CAM software we use to add to this to hopefully make it as relevant as possible.
Good luck!!
"Engineering is a great profession. There is the satisfaction of watching a figment of the imagination emerge through the aid of science to a plan on paper. Then it moves to realization in stone or metal or energy. Then it brings homes to men or women. Then it elevates the standard of living and adds to the comforts of life. This is the engineer's high privilege."
-Herbert Hoover
Unread 26-01-2013, 18:24
DonRotolo's Avatar
Back to humble
FRC #0832
Another alternative is to select a face of your part, and then export it as DXF. Most CAM programs can handle DXF input.
Your absolute best bet is to ask them what file format they need.
