Go to Post FRC is a game of mentors. The best teams are guided by mentors who know how to balance on the knife edge of pushing the envelope and achieving success. - Mr. Van [more]
Unread 20-01-2013, 22:44
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
Team Role: Leadership
Rookie Year: 2012
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
How to change angle of shooter?
I saw a similar thread but wasn't seeing the kind of discussion I had in mind.
For changing the angle of a launcher, how would you go about doing it?
Assume point blank that it's a 20" shoot with one or two wheels on one side. Now where do we go?
I'm just lost as to what kind of motor to use, reduction to use, gearbox to use, but most importantly how to even mount the launcher to some kind of pivoting mechanism that utilizes that motor. Just lost.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 20-01-2013, 22:49
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Team Role: Teacher
Rookie Year: 2007
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: How to change angle of shooter?
One idea is to fix one end as a point of rotation and use a lead screw to adjust the other end.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 20-01-2013, 22:57
ksafin's Avatar
AKA: Kirill Safin
Rookie Year: 2012
I like this idea.
Unread 22-01-2013, 20:47
G-Hence G-Hence is offline
FRC #1261
G-Hence is just really niceG-Hence is just really niceG-Hence is just really niceG-Hence is just really niceG-Hence is just really nice
This by far is probably the easiest way to change the elevation to a know point. Pneumatic pistons could work but there would be more guessing involve? Anyway, check out throwing machines like baseball pitching machine, football thrower, artillery guns, and even skeet launchers.
"Never let the fear of striking out get in your way."
-Babe Ruth
Unread 22-01-2013, 21:24
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
KrazyCarl92 has a point that I think should be considered regarding pneumatics - one of the trickiest things about any shooting game is trying to come up with a clever way to correlate distance and target elevation with shooter elevation. I highly, highly recommend that teams take their prototypes (or their calculators) and figure out specific angles and shooting speeds that result in a wide range of potential shooting positions - namely, what angle and speed can you set up such that the angle of the shooter changes as little as possible and yet still allow for scoring over much of the field. Then, using pneumatics (or ball screws with limit switches at set locations) pick two or three angles that together will cover all your bases and leave it at that (if you use pneumatics, you might have to do multiple stages or attempt a 3-way valve solution, but much, much easier than a continuous motion solution). It's cool as all get out when you have a system that can automatically track a target in azimuth and elevation, but 9 times out of 10 the system will still be messing around when your window for shooting comes and goes.
Just food for thought.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 22-01-2013, 21:42
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is online now
45 Alumni
AKA: Peyton Yeung
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
We are looking at an arm like shooter in which we run a keyed shaft as a pivot and using sprockets rotate the whole assembly
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
Unread 22-01-2013, 21:52
kingbrandon14's Avatar
kingbrandon14 kingbrandon14 is offline
FRC 4188 Engineering Mentor
AKA: Brandon King
FRC #4188 (Columbus Space Program)
kingbrandon14 will become famous soon enough
Arrow Re: How to change angle of shooter?
We are planning to use an igus lead screw (picture above) attached to a strong motor to move the front end of the shooter up and down. We are still debating whether we should have two of these mechanisms (one on each side), or just one.
Another idea is to use pneumatics, but the disadvantage of that is there are only 2 positions: all the way up, and all the way down.
2012 Peachtree Regional Rookie All-Star; 2015 Peachtree Regional Winner; 2016 PCH District Columbus Winner, Albany Finalist & EI; 2016 Rocket City Regional Finalist, Wildcard
Unread 07-02-2013, 16:01
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
We have a lead screw being used to adjust our shooter mechanism, which for the most part, is working like a charm. I cant believe the 1st banebot gearbox ratio we chose was the best one.
Initially after the shooter was built, we mounted it to a varying angle extruded aluminum frame to match the height where we designed the shooter to be. From there we determined the optimal angle range of the shooter head. Thus, the decision to design a varying angle shooter using the lead screw was determined.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Unread 08-02-2013, 16:47
jp1247's Avatar
jp1247 jp1247 is offline
No the cRio does not like aluminum!
FRC #1247 (ROK BOT)
Rookie Year: 2010
jp1247 is an unknown quantity at this point
Not entirely true. I spent last weekend testing the plausibility of pneumatic angling. By using a dual solenoid, and 1 spike controlling it, im able to get infinite variation with no lack of strength.
The solenoids two red leads go to M+ and M- of the spike, the black going into a splice on the ground side of the spike. By setting the the spike to full forward (12 volts on both pins, 0 pot. difference) the cylinder hold position due to equal pressures. I can then simply set the spike to forward or reverse to raise and lower the piston, having it default back to holding. On a 1"" bore bimba piston, i cant move the shaft at all. Flow control valves on the piston allow me to control how fast it moves up and down.
I may link a video if i get the chance on sunday...
"No, you can't use the Kinect to do pelvic thrusts."
Unread 22-01-2013, 21:53
Herbblood's Avatar
Herbblood Herbblood is offline
Knowledgeable
AKA: Ally
FRC #3044 (OxBE4)
Herbblood is an unknown quantity at this point
How about just having a belt system with a motor? We're using something based off of this, and with the right motor you should be able to left your shooter around the center of gravity on a pivot point.
Off to WPI!
Go OxBE4
Unread 22-01-2013, 22:51
JCharlton's Avatar
JCharlton JCharlton is online now
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
How about a spring to hold the shooter in the up position, and a winch mechanism to pull it down against the force of the spring? Simple pivoting joint, simple little winch one a motor. Simple is good. We're going lead screw, but it's not simple.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 03-02-2013, 15:39
capnslow capnslow is offline
FRC #3131
capnslow is an unknown quantity at this point
Wow, I really like that idea.
We're using a lead screw, I don't know where we got it but it's 8 threads per inch and we're going to drive it with a cim-u-lator. Seams crazy fast but the testing we've done shows it's not too bad.
Unread 20-01-2013, 22:52
Darth Drew's Avatar
Darth Drew Darth Drew is offline
AKA: Andrew
FRC #1701 (Robo Cubs)
Team Role: Student
Rookie Year: 2011
Darth Drew is an unknown quantity at this point
We're facing the same problem, we were wondering about using a worm gear to drive it with some kind of hinge for the pivot point. (BTW we're not using a turret)
Join me and together we will rule the galaxy
Unread 20-01-2013, 23:01
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is online now
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
Rookie Year: 2010
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
There are several ways to get this type of motion with a motor. One is to use a large gear reduction to generate the amount of torque you need to get the motion you want. Another way is to convert the rotary motion of the motor into linear motion with a lead screw for example, as shown in this video for a robotic arm. We used a lead screw with a PG71 gearmotor to adjust the angle of our shooter last year. A rack and pinion type of mechanism may also achieve the motion you are looking for. Many times a counterbalance is applicable to take some of the load off of the motor, increase speed, and/or increase reliability. This could be a type of spring, surgical tubing, gas shocks, or any other way that energy can be stored to counteract gravity or other external forces that the motor will need to overcome to tilt the shooter.
Our team is heavily considering pneumatic actuation as a solution to tilt our shooter because we believe that having a known position without sensor, set point, or mechanical error will be beneficial for consistent shooting, and our strategy does not rely on being able to have a continuously variable shooting angle. A position for starting configuration and another for shooting is enough.
[2016-present] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
  #15   Spotlight this post!
Unread 21-01-2013, 06:38
Spirator Spirator is offline
AKA: Munaum Muhammad
FRC #3132 (The Thunder Down Under)
Rookie Year: 2010
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
We know what angles and range we'll need to shoot from so depending on how we decide to play our strategy we'll have a fixed angle or adjustable between two positions using a pneumatic cylinder.
We use pneumatics because they're very good at holding one position and don't need any feedback control.
