Go to Post I think Dean has surpassed my 12 minute prediction.... - Koko Ed [more]
  #31   Spotlight this post!
Unread 10-02-2013, 14:39
Justin Shelley's Avatar
Justin Shelley Justin Shelley is offline
FRC #3885 (Shockers)
Team Role: Driver
Rookie Year: 2012
Justin Shelley is on a distinguished road
Send a message via MSN to Justin Shelley
Re: How to change angle of shooter?
A variable shooting angle is a great idea but we decided that it is not entirely necessary because our shooter is pretty accurate within a twenty foot distance. Though i still want a variable angle mechanism for our robot
  #32   Spotlight this post!
Unread 10-02-2013, 16:38
fsracer fsracer is offline
Mentor team 3137
AKA: Frank Saladino
FRC #3137 (Thunderbirds)
Rookie Year: 2000
fsracer will become famous soon enoughfsracer will become famous soon enough
We used a small dana linear actuator. Replaced the motor with a legal one. The motor had the same mounting and shaft size! we just cut a d drive in the shaft and it bolted right in.
The actuator was rated for 75 lbs max, and had a 12" stroke, as well as auto limit switches built in. It used 3/8 Bolts to mount.
The conversion took about 15 minutes to do.
And maybe if we used 2, and set the shooter with hooks at 31 inches . . .
Good luck and watch the safety!!
BTW, we used 2 pneumatic cylinders in series to get 3 positions. (1 out, 2 out, none out) for steering a past bot.
Mr. S., Mentor team 3137
