Go to Post Indeed, the more ways you fail, the more ways you know something doesn't work.:) - Steven Sigley [more]
Unread 20-01-2013, 23:11
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
Rookie Year: 2011
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
cRIO messing up
We have tried imaging our cRIO and it keeps failing.
However it reads that we have the new image on the cRIO.
So we have tired to deploy code onto and it fails to connect to the real time target.
Any help?
Thanks
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 21-01-2013, 00:40
andreboos andreboos is offline
FRC #3021 (The Agency)
Rookie Year: 2010
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
Re: cRIO messing up
You need to address the imaging issue first - when new images are released (as they likely will before competition), you'll need to update to them before you can compete.
Could you give more details about how the imaging process fails?
What programming language are you using?
What is your network configuration?
Unread 21-01-2013, 01:12
team3039 team3039 is offline
FRC #3039
team3039 is an unknown quantity at this point
Re: cRIO messing up
Make sure that your network settings are set correctly, or else it's doomed to fail.
