Go to Post If you aren't sure, Q&A. Now. - EricH [more]
Unread 21-01-2013, 11:39
ctccromer's Avatar
ctccromer ctccromer is offline
Animus
AKA: Tucker Campbell
FRC #3753 (Bulah Bots)
Rookie Year: 2012
ctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to all
Labview Simulator Issues
So I have set up the simulator like this:
Plugged in our joystick via USB drive
Open RobotMain.vi
Changed the run location from the cRIO to MY Computer
Opened the driver station
Ran the code from the front panel of RobotMain.vi
enabled the robot from the driver station
When I clicked run, the simulation opened successfully and started to run.
The problem is that when I went to enable the robot, an error window popped up.
[Screen shot attached]
Can anyone give me some advice as to what to do?
Thanks
