Go to Post No amount of sleep beforehand will make up or prepare you for the lack of sleep you will receive during build season. - Dan Petrovic [more]
Unread 21-01-2013, 13:05
HiNRah HiNRah is offline
FRC #4032
Rookie Year: 2012
HiNRah is an unknown quantity at this point
Wind River License Issues
I'm getting a message that says my license for windriver expires in ten days. Anyone know what's wrong?
Unread 21-01-2013, 16:18
xraymypanda's Avatar
xraymypanda xraymypanda is offline
Cowboy programmer
AKA: Chris M
FRC #0599 (RoboDox)
Rookie Year: 2011
xraymypanda has a spectacular aura aboutxraymypanda has a spectacular aura about
Re: Wind River License Issues
Given your team number, I am going to assume you are on a rookie team or 2nd year team. Did you install Windriver fresh this year or reuse last year's installation? If you installed Windriver this year you must not have used the right file for licensing. The file containing the year license is found on the Installation CD and is not labeled as only license but as FRC_2013_WB30_WB33_install.txt
See this for more information: http://wpilib.screenstepslive.com/s/...elopment-tools
If you are a second year team, go to the link above and follow the instructions for installing 2013 over the 2012 installation. You can follow the same instructions to repair your license.
2011: Head Scout
2012: (figure)Head Programmer
2013: Head Programmer, Chief Strategist, Outreach Executive, and Driver
Unread 23-01-2013, 18:54
FRC #4032
Rookie Year: 2012
We are a second year team, I believe one of our team members finally found our problem, we were told to let the license expire and then try to reinstall it, I believe, but we're not having the issue anymore. Thanks, though.
