Go to Post I'll do my best, but I'm this --><-- close to telling our drivers they're NASCAR styling it this season..."Sorry boys and girls, left turns only!" - Mr. Lim [more]
Unread 21-01-2013, 14:32
Team3763 Adam Team3763 Adam is offline
Lead Programmer
FRC #3763 (4H WildCards)
Rookie Year: 2010
Team3763 Adam can only hope to improve
One Motor Autonomou
Just making a simple code where a single motor with a jaguar will run for 5 seconds then stop.
What code would I use to execute this? I get to calling up the code then getting the output, but I can't add a time and inputs for power.
Unread 21-01-2013, 14:42
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: One Motor Autonomou
For a timed action you can put the code in Periodic Tasks.vi.
With a state-machine you could put code in Teleop.vi
There are lots of different ways to do something like this.
Here's an example that could be used in Teleop.vi
You'd add your Set Motor in the True case, and add another case outside to the right that used Time to do it? as a flag to stop the motor.
This example for Periodic Tasks.vi would just need the two sequence frames that do the Motor sets to start, then stop the motor.
Ignore the Servo stuff. They were demonstrating extra actions.
Unread 21-01-2013, 18:10
Lead Programmer
Rookie Year: 2010
Re: One Motor Autonomous
What about in Autonomous period? With two motors you can attach a timer to have a motor running for x amount of seconds, but you can't attach the timer to a One motor item.
WPI Robotics Library -> Robot Drive -> Advanced is the location of said timer.
Unread 21-01-2013, 18:35
Just Itinerant
Here's an Autonomous Independent.vi example.
Just replace Tank Drive with Set Motor, Left and Right Motors refnum Get with a Motor refnum get, and you don't need the Safety Config.
