Go to Post The possibilities for zip ties are endless. - Elgin Clock [more]
Unread 22-01-2013, 21:31
Brandon_L Brandon_L is offline
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
Re: Full Court shot
That looks like the AM Pneumatic wheel. Were also using that, but it wobbles insanely. How did you manage to fix that? Yours looks pretty stable.
FRC 2495 - Hamilton West Robotics [2007-2014] - whats a..."hive mind"?
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
Unread 23-01-2013, 01:33
bfk bfk is offline
FRC #2521
Rookie Year: 2011
bfk is an unknown quantity at this point
Re: Full Court shot
Basically, first of all make sure your motor mount is very stable.
Make sure the hub is perfectly centred on the wheel. We used some thin grippy material between the wheel and the hub to prevent it slipping. Make sure all six bolts are tight.
Then find a piece of something that can fit in the hole in the hub and suspend the wheel like a plumb bob. You'll see it list a lot to one side or the other. The weight of the fill tube leaves it way off balance. Attach weights to the wheel until it balances as perfectly as you can get it. Make very sure that the weights are securely attached, these wheels are really moving fast and a couple of grams at that speed will do serious damage. See Jason's post above.
Then everything is great and hopefully your team-mates will have developed the world's best climber while you were working on the shooter. That part didn't work out that way for us, but a guy can dream.
Unread 23-01-2013, 01:20
bfk bfk is offline
FRC #2521
Rookie Year: 2011
Re: Full Court shot
Originally Posted by neaanopri View Post
Out of curiosity, what gear ratio were you using?
Gears? We don't need no stinking gears!
It was direct drive off a CIM, running at about 90% power.
Unread 23-01-2013, 09:39
TeamUpNext3528's Avatar
TeamUpNext3528 TeamUpNext3528 is offline
FRC #3528 (Team UpNext)
Team Role: Driver
Rookie Year: 2011
TeamUpNext3528 is an unknown quantity at this point
Re: Full Court shot
WoW! That was awesome! Our team is going for the same approach. We are wanting to shoot full court shots. But that really depends if our shooter is accurate enough.
And I do agree, there could be air flow getting in the way of those long shots depending on where the regional is.
Unread 23-01-2013, 23:30
Willyspu Willyspu is offline
AKA: Jim
FRC #2144 (Gators)
Rookie Year: 2007
Willyspu is a jewel in the roughWillyspu is a jewel in the roughWillyspu is a jewel in the roughWillyspu is a jewel in the rough
Re: Full Court shot
Any tips on balancing the wheel?
Unread 23-01-2013, 23:37
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Rookie Year: 2012
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Full Court shot
Our team stuck a couple of long screws to the inside of the wheel opposite the valve. It seems to be working so far...
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 24-01-2013, 01:03
Re: Full Court shot
Here's our full court shot - http://www.youtube.com/watch?v=rNT5c...Jchc5w&index=5
Unread 24-01-2013, 06:25
rai337 rai337 is offline
FRC #1574 (Miscar1574)
Rookie Year: 2012
rai337 is an unknown quantity at this point
Re: Full Court shot
Originally Posted by Akash Rastogi View Post
what wheel you used? we've been trying pneumatic wheels and rubber wheels and the pneumatic wasnt stable, while the rubber didnt have much power..
Unread 20-02-2013, 15:17
SciBorg Dave SciBorg Dave is offline
AKA: Dave Tharp
FRC #5920 (VIKotics)
Rookie Year: 2012
SciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to behold
Re: Full Court shot
Team 4061 went to a tire store and got stick on wheel weights.
The valve stem was the heavy spot so we added 2 wheel weights at 120 and 240 degrees from the valve stem. This gave 3 points of weight the valve stem and the stick on weights. We had to use 1/4 oz at the 2 points. This worked very well to rid vibration.
Unread 21-01-2013, 23:09
bfk bfk is offline
FRC #2521
Rookie Year: 2011
Re: Full Court shot
Originally Posted by DonRotolo View Post
Nice video. That looks awesome. I assume you know there might be a pyramid on the field, so that's why you programmed in that little curve at the end....
Of course.
