Labview Dashboard issues???
So i followed the FIRST 2013 tutorial on putting stuff onto the dashboard, and i followed each step to the dot, but nothing on the dashboard responds to anything i've set it to respond to!
I used the SD read and write .vi's ("write" in the robot code and "read" inside a while loop in the dashboard main) and not one boolean LED lights up when a switch is pressed. Is there something wrong with the way I have the read and write vi's set up in each of the attached files? |
