Go to Post If you're the smartest person in the room, you're in the wrong room! - Ian Curtis [more]
Unread 21-01-2013, 20:36
KissMySass3763 KissMySass3763 is offline
3763
AKA: Madeline Mapes
FRC #3763 (Wild Cards)
Rookie Year: 2012
KissMySass3763 is an unknown quantity at this point
Autonomous Just Became Auto-LOST!
After attempting to unlock the secrets of autonomous programming, I believe I have hit a dead end. The example written out as default in LabVIEW for autonomous only confuses me more. To get my program to run the robot's drive, then call up a single motor to shoot, given the signal by a sensor (which I am also clueless on how to program) would I use a case structure, no structure, or another structure whch I do not know of?
Thank you,
Madeline
Unread 21-01-2013, 20:59
Re: Autonomous Just Became Auto-LOST!
The first thing I'd recommend is to describe the goal as specifically as you can. Programming tools are called languages because they are used to describe and convey the steps and details, ultimately to the computer, but often to other programmers. Until you are more fluent in this new language, use the one you know. The computer won't understand it, but the other people will, and it will help you to clarify the steps you want it to take.
The next thing is to translate where you can into LV. If you aren't sure or have questions, give the description and post the questions here or run them by your mentors.
Greg McKaskle
Unread 22-01-2013, 09:59
3763
AKA: Madeline Mapes
Rookie Year: 2012
Primarily, I wish to call up the drive motors and run them for a short period of time, stop the drive, and then call up the single motor which will eventually be acting as out shooter, and run this single motor for a short period of time. Nothing crazy, I just want to write a basic code to see what wil need adjusting.
Thank you,
Madeline
Unread 22-01-2013, 10:16
I attached a possible translation based on the template autonomous.
Greg McKaskle
Unread 22-01-2013, 10:56
3763
AKA: Madeline Mapes
Rookie Year: 2012
Thank you! That helps to clear things up.
