Go to Post Admiring the new chassis: "Oooo, nerd bling!" - Rick TYler [more]
Unread 22-01-2013, 08:54
daniel02010 daniel02010 is offline
FRC #1657
daniel02010 is an unknown quantity at this point
Control compressor PSI
My compressor allways get 80 PSI when my air pressure is going down can i do someting and give to the compressor like 100 PSI and not 80 PSI
Unread 22-01-2013, 09:07
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Control compressor PSI
The working pressure side, where the solenoid valves are, must be 60 psi or less.
The high pressure side, where the compressor is, should be at 115 to 120 psi.
If your high pressure side cannot get above 80 psi, then the high pressure regulator might be plumbed incorrectly.
On the regulator look for an arrow. The tail of the arrow points to the only port that can be high pressure.
If any other port gets the high pressure line, the regulator won't allow pressure to go above whatever it is set for.
Another less-likely possibility is that the pressure safety valve is way off and needs to be adjusted.
