Go to Post Because the new control system weights as much as a fully-loaded M1 Abrams Tank. - artdutra04 [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 23-01-2013, 07:02
matthewgkerr matthewgkerr is offline
FRC #4529 (Team Melbourne)
Rookie Year: 2012
matthewgkerr is an unknown quantity at this point
Create a rectangle
Ok, so this is a real noob question. I'm trying to create a rectangle while i'm watching a tutorial. It says to select the rectangle tool (I think it is the two point rectangle) only I don't have that available. I have the 3D Sketch bar open, but all I see in the Draw tab is:
Line
Helical Curve
Arc
Spline
Equation Curve
Point Bend
I tried right clicking on the ribbon and customising the user command. I added Rectanle (Two Point) to Part | 3D Sketch, but I didn't see anything change in the Ribbon. Any suggestions?
Unread 23-01-2013, 10:01
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Re: Create a rectangle
Line
Helical Curve
Arc
Spline
Equation Curve
Point Bend
It sounds like you actually should be using "Create 2D Sketch" to do what you want. 99.9% of the time for FRC-type situations, you should only use 2D sketches for simple extrudes, revolves, etc, as these parts are all relatively simple. CIM motors, gears, sprockets, aluminum extrusion, etc. can all be modeling using only 2D sketches.
The only real reason to use 3D Sketches is to create complex/surface modeling features, such as guide curves for loft operations or contour splines for surface modeling. These features are only useful for creating complex curves, like ergonomic handles for consumer products or the body panels for a car.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 23-01-2013, 12:43
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Rookie Year: 2011
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Line
Helical Curve
Arc
Spline
Equation Curve
Point Bend
You need to create a "2D Sketch". You can't draw rectangles in a 3D Sketch because they're 2-Dimensional shapes. I always have my Inventor set up to create a 2D Sketch whenever I create a new part.
Unread 23-01-2013, 15:59
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
The previous comments all give the correct advice, you need to create a 2D Sketch and then the Draw panel is displayed with all the basic sketch tools you need.
Let me know if need any more help.
Also, try these videos for basic Inventor help.
http://curriculum.autodesk.com/stude...2/category_id/
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 24-01-2013, 06:30
Rookie Year: 2012
Thanks for everyone response. I figured out what I did wrong. It looks like a clicked on "Create 3D Sketch" and I didn't know how to get out of it. I've since found the "Create 2D Sketch".
