Go to Post Point is, there is no definite answer. This is FIRST, Whatever works well with your team is the best. - NelsonMichael [more]
Unread 24-01-2013, 06:59
matthewgkerr matthewgkerr is offline
FRC #4529 (Team Melbourne)
Rookie Year: 2012
matthewgkerr is an unknown quantity at this point
CIM motor and 8mm key hub
Our team is looking at using andy mark gear to launch the disks. Namely, using the large CIM motors and pneumatic wheels connected using an 8mm key hub. With the wheel sitting on top of the motor, the key hub rests on the face of the motor. To me this seems far from desirable. How have other teams attached their CIM motors to the pneumatic wheels?
Unread 24-01-2013, 09:23
CidTeach CidTeach is offline
Mechie
AKA: Mr. C
FRC #0334 (Tech Knights)
Team Role: Teacher
CidTeach is just really niceCidTeach is just really niceCidTeach is just really niceCidTeach is just really niceCidTeach is just really nice
Re: CIM motor and 8mm key hub
Which ever method you use, please be reminded no motor likes to see a bending load on its shaft. this means no direct placement onto the cim motors keyed shaft. Look into a small reduction gearbox of some type that suits your design criteria or do your best to support the final output shaft through the use of bearings or bushings.
Hope this helps. Many motors fail "unexpectedly" when loaded directly either in competition or on bench testing.
Unread 24-01-2013, 10:22
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Team Role: Teacher
Rookie Year: 2007
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
One of our prototypes that is similar to yours has a "cage" over the wheels. From there two dead axle/bearings set ups drop down into the wheels to help support any lateral movement of wheels on the output shaft of the CIM.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 24-01-2013, 14:50
AlexH AlexH is offline
Rookie Year: 2010
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
you could cut 3/8" off the boss on it and clamp the hub on with a 8mm shaft collar.
My Instructables
Unread 24-01-2013, 16:04
Rookie Year: 2012
Hi Phyrxes. Our working design included a cage (still a build in progress) with a bolt dropping down into a bearing in the top of the wheel. Hopefully this would prevent bending. What I wasn't sure about was if I should have this bolt floating inside the wheel, or if I should turn it around and have it supporting the weight of the wheel. Supporting the wheel would then prevent the hub from contacting the motor... either way I still think I would prefer a dead axle extending all the way through and drive the motor using a belt... any other thoughts?
Unread 24-01-2013, 16:20
Phyrxes's Avatar
AKA: Dave Button
Team Role: Teacher
Rookie Year: 2007
The first generation prototype had a spacer between the hub and motor, our second generation (currently being fabricated) has the motor above the wheel.
Dave Button
Wakefield School
The Plains, VA
Unread 24-01-2013, 16:33
Rookie Year: 2012
I did have the the thought of putting the motor above the wheel. I'll need to sit down and think about this more. There seems to be a lot of assumptions in other threads about what the CIM motors can and can't do wrt to radial load, high current draws and use with and without gear boxes. It makes it very difficult to know how we should or should not be using the motors.
Unread 24-01-2013, 16:45
Phyrxes's Avatar
AKA: Dave Button
Team Role: Teacher
Rookie Year: 2007
We aren't running ours at full speed, as a number of people have posted video running a slight speed difference between the wheels and still only about 50% input was getting 30 ft shots.
Dave Button
Wakefield School
The Plains, VA
