Go to Post Mostly, however, I find that once the students start building a robotics project, they are too busy learning for me to teach. - dtengineering [more]
Unread 25-01-2013, 01:35
TheMadCADer TheMadCADer is offline
Rookie Year: 2010
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
Re: How far are people shooting?
Originally Posted by SoccerTaco View Post
If you pop forward solely to draw a foul, does 18-1 come into play here and negate the foul on the blocker?
Rule 18-1:
Strategies aimed solely at forcing the opposing ALLIANCE to violate a rule are not in the spirit of FRC and are not allowed. Rule violations forced in this manner will not result in assessment of a penalty on the target ALLIANCE .
No, the rule regarding the feeder and pyramid safe zones specifically designates that it doesn't matter who initiates contact.
18-1 is intended to prevent things like loading discs into another robot so it has more than 4 or pushing an opposing robot into one of your own partners that is trying to climb, so that the opposing robot gets huge penalties.
Unread 25-01-2013, 01:59
Wildcats1378 Wildcats1378 is offline
Rookie Year: 2011
Wildcats1378 is an unknown quantity at this point
Our shooter has been tested at 27 feet into the top goal consistently, but we've shot 50+ feet into someone's outstretched arms 7 feet in the air. Need some more testing
So far, some of the most important things We've learned is that:
There has to be a stable, stable back wall.
If it's a circular shooter, more compression tends to shoot it farther.
No skid tape helps a lot.
Our shooter was shooting like 10-15 feet, and it was a bit disappointing. We were about t give up, but we just moved the wheel in like 1/4 in, and it started FLINGING those things out to 40 feet or so.
Unread 27-01-2013, 13:27
dchartley dchartley is offline
FRC #3684
dchartley will become famous soon enough
We are going to go for the full court shot, probably at the larger target. Our Team developed a 3 wheel system using 2 wheels on the horizontal plane that are belted together and run direct drive off a single CIM and single wheel in the vertical plane that runs direct drive off another CIM. Top wheel is mounted slightly to left of center. Velocity is running over 30 fps and is flying flat and stable. Probably going to have to make some hefty guards for the fast spinning wheels in case of failure.
Doug
http://youtu.be/i4LRvcwTFEA
Unread 29-01-2013, 10:15
TheCrayButton's Avatar
TheCrayButton TheCrayButton is offline
FRC #3528
TheCrayButton has a spectacular aura aboutTheCrayButton has a spectacular aura about
Doug
WOW! That is a great shooter! Very interesting design. I never thought of mounting the well above the frisbee before!
My team is shooting consistently at 60ft away. We are planning on shooting full court, but we don't have to if we are blocked.
VIDEO:http://www.youtube.com/watch?v=BzIke...er_profilepage
Unread 03-02-2013, 01:39
capnslow capnslow is offline
FRC #3131
capnslow is an unknown quantity at this point
We're shooting full court, I don't know what our max range is though. Our shooter is a very different design and is powered by two (2) PG71 motors.
Unread 24-01-2013, 14:17
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Originally Posted by jwfoss View Post
Our question during prototyping: Why shoot farther then you need to?
This!
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 24-01-2013, 14:21
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
Rookie Year: 2012
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Even more importantly, how accurate are people from various distances. I humanly can easily throw a frisbee 50 maybe 100 feet. I also might kneecap a referee with it.
Unread 24-01-2013, 14:07
Negative 9 Negative 9 is offline
FRC #0611
Negative 9 is an unknown quantity at this point
Our prototype got around 10-15 ft as well, but we're waiting on some parts that should hopefully let us shoot from a lot farther.
Unread 24-01-2013, 14:51
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Originally Posted by nuggetsyl View Post
10 feet 8 3/4 inches give or take 1000th of an inch. Boy I hope the feild is build to spec?
Hahahhaa.
We're shooting from three hundred feet. Maybe they'll let us shoot from the queuing line?
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 24-01-2013, 16:03
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
Originally Posted by Nick Lawrence View Post
Hahahhaa.
-Nick
You will have to shoot over the net, would be pretty impressive
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
Unread 24-01-2013, 20:11
Commander Canada
That curve.
-Nick
Unread 24-01-2013, 15:00
ctccromer's Avatar
ctccromer ctccromer is offline
Animus
AKA: Tucker Campbell
FRC #3753 (Bulah Bots)
Rookie Year: 2012
ctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to all
during our prototyping, when we tested just to see how far we could shoot it at the one (not adjustable) our shooter is set at, we shot about 40-45 feet
EDIT: and at a glance, the shooter angle seems to be about 35 or 40 degrees
