Go to Post last year's tradition is this year's rule change! - EricH [more]
Unread 24-01-2013, 23:43
wdburk3160 wdburk3160 is offline
AKA: William Burk
FRC #3160 (F.R.O.G.)
Rookie Year: 2011
wdburk3160 is an unknown quantity at this point
Vision Processing VI Problem
Well, I'm not going to ask about tracking. I have simply been opening a new cRIO project and while it is configuring it pops up a message about some Vision subVI that i don't have permission to use. I don't have the specific computer available at this moment, so I don't have the exact message. I can still configure the project, but in robot main, it says the Vision VI is not executable. I have tried other computers and they configure and don't open with any errors. I have a feeling that it might be something that happened during installation, but I am not absolutely sure. Does anyone have a suggestion as to what might have happened and/or a way to fix it?
Unread 25-01-2013, 01:06
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Re: Vision Processing VI Problem
I have installed LabVIEW and it's various FRC Updates on six laptops we use for our LabVIEW class, the laptop we use for our driver station, two laptops of my own and several students laptops. When a message like that pops up, it's often some piece of the programming system (LabVIEW is far from 'a' program, it's a large number of small programs working together) that didn't get installed correctly, or has become corrupted.
Usually, a reinstall fixes it. I can hear you groaning, but fortunately, a reinstall usually goes fast, as the installer is smart enough to skip over the parts that are already there and only does the missing pieces.
Sometimes, the message gives you a clue about where the missing piece comes from and you can go straight to say, the FRC LabVIEW Updates. Otherwise start with the main LabVIEW and then go through the update installs. This type of error is usually not the Utilities or Driver Station Updates.
I have been carrying the updates as well as an ISO image of the LabVIEW disk on a thumb drive and it comes in handy when fixing these sort of problems.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 25-01-2013, 06:54
It sounds a bit like IMAQ, or NI-Vision is its other name, may not have been activated. You can do this in the Start>>National Instruments>>NI License Manager. You may need to contact NI support in order to complete this, as I find it pretty confusing to use.
The other option is that you don't have the newest version, in which case the solution is to install it from the DVD. Hopefully the dialog will give you an idea of which is more likely the problem.
Greg McKaskle
Unread 25-01-2013, 09:33
AKA: William Burk
Rookie Year: 2011
I do have the newest version. I will reinstall labview on that computer when I get the chance. Thanks for the replies.
Unread 26-01-2013, 12:27
AKA: William Burk
Rookie Year: 2011
Thanks for the replies, we got Labview reinstalled on that computer and now everything is fine.
Unread 10-02-2015, 22:31
apm4242 apm4242 is offline
FRC #4242
apm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud of
Greg McKaskle
I had this problem, too. I thought I had activated everything during the install but I guess not. Activating through NI License Manager fixed it.
Thanks Greg
