Go to Post This our big chance to spread the word and change the culture, let's not waste it. So in the words of one Leroy Jenkins, "Time's up, let's do this." - Frenchie461 [more]
Unread 25-01-2013, 13:30
Gadeer Zbedat Gadeer Zbedat is offline
FRC #1946 (Mishka Monster)
Rookie Year: 2012
Gadeer Zbedat is an unknown quantity at this point
Jaguar configuration problem
Hiii guys , )))
I wanna ask your help !!! I've fall in a delima
How can I know if the Jaguar is working ?!!
because I doubt that some jaguars are bad !!
Unread 25-01-2013, 13:41
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Re: Jaguar configuration problem
What is the Jaguar currently doing? What is the light on it doing when you try to run your code?
Unread 25-01-2013, 13:44
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Here is what you're looking for.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 26-01-2013, 11:43
Rookie Year: 2012
but how can I know that the jaguar is working with configuring it to the Power Distribution Board???!!
Please help me !! I've stuckk in this problem ((((
Unread 26-01-2013, 11:54
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Gadeer,
You will need to power the Jaguar to tell if it is working. First connect the input power to the PD and see if it will wake up. You should see the lights on the PD come on and the Jaguar fan should spin and the LED on the Jaguar will blink. If all of this is good, check PWM operation of the Jaguar. You will need to have software running with the Jaguar PWM commands. Enable and watch the LED on the Jag. You should be able to command it for forward and reverse. If it reacts normally, try connecting a motor and rerun the above tests.
Al
WB9UVJ
www.wildstang.org
________________________
