Shooting issues
Hii
We need help with our shooter.our shooter is not shooting high enough that we want it just go little bit and fell. we try everything to make this shooter to shoot proper distance.....but same thing....I need your help please help us .......thank u. ![]() |
Re: Shooting issues
Describe the shooter please. We can't help otherwise
Re: Shooting issues
Details needed. Linear or curved shooter? What motors are you currently using? What wheels and what size? Are you using any gearboxes?
Re: Shooting issues
This moters connected and btw we are rookies soo
Re: Shooting issues
My guess is that you aren't getting enough torque to make the speed useful or way too much compression. Have you tried 1:1 with the cims?
Re: Shooting issues
Other pic is here
Re: Shooting issues
Yeah we did try
Re: Shooting issues
Are the discs hitting the bolts you have holding the shooter down? Any idea on what your compression is?
Re: Shooting issues
I don't think is hitting the bolts and idk about that......
#10
Re: Shooting issues
Can u give us an idea how u connect those directly to motor bec we try didn't work so we have to use gears.....
#11
Re: Shooting issues
I would highly recommend mounting it so that those bolts aren't there right at the exit. There's almost no way that isn't causing a problem. Try bolting through the side walls above the area discs travel through, or the top surface.
Another issue could be that your wheels aren't lining up well with the flat edge of the disc, so they aren't getting a good contact. If you can get the center of the wheel tread to touch the disc on the flat edge, you should get good results. Also, I'm assuming you've fiddled with compression and motor speed, but if you haven't, that's step 1. |
#12
Re: Shooting issues
Most of the linear shooters that people are using are using an overdrive setup for their gears. It appears from your picture that you have a small gear on the motor and larger gear on the wheel which will reduce the motor output rpm. Maybe try putting a larger gear on the motor?
Regards, John 37777 Mechanical Mentor |
#13
Re: Shooting issues
Also you may need something with some grip to it on the opposite wall from the wheels. This will allow the frisbee to spin more. More spin = more stable flight
John 3777 Mechanical Mentor |
#14
Re: Shooting issues
#15
Re: Shooting issues
Ok and other thing do we have to,have tight enough both side to throw higher frisbee.
